Iroc to caddy starter probs Help!
Old Jun 14, 2012 | 11:43 PM
usmcirocz's Avatar
Ok so I knew there was a swap from tpi to throttle body and the engine he said came out of a 93 caddy limo I'm guessing the fleetwood? Now I'm replacing my starter and I can't get it to line up right I was using the iroc starter and yes I know use the caddy one instead already tried that the 89 iroc and 93 caddy are pretty much the same what do I do. I'm leaving for afgainistain soon and need this car running someone help me please!
Old Jun 15, 2012 | 12:06 AM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
Re: Iroc to caddy starter probs Help!
Well if the engine is from a caddy and the starter from the caddy is present, it should fit. Im confused as to why it wont line up.
If the iroc one was working, maybe you can just get another iroc starter like yours and use it
If you arent sure what the engine is out of, are you positive its the correct starter for the engine? Or did you just go get a fleetwood starter in hopes of it fitting?
Old Jun 15, 2012 | 03:47 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Starter to block or starter to flexplate ?
But what pattern bolt holes in the block do you have ?
which starter type do you have ,inline bolts or offset
Do bolt holes match those in the block?
Old Jun 15, 2012 | 06:55 AM
usmcirocz's Avatar
Mine looks just like the one in the pic and the holes on the starter are in line. Should I try a offset starter? It's the flexplate
84z96L31vortec
Aug 20, 2017 12:16 AM
Derick15
Sep 17, 2016 05:28 PM
Accerrito22
Aug 23, 2015 07:22 PM
mustangman65_79
Aug 11, 2015 03:17 PM
milk
Aug 10, 2015 06:26 PM
