car wont start, crank
Old Jun 16, 2012 | 08:23 PM
91 camaro rs's Avatar
Car: 91 rs
Engine: 305tbi
Axle/Gears: 3.27 9bolt
I went to start my car yesterday and it wouldn't start. It won't even crank. The battery is hood. What else should I look for?
91 camaro rs
305tb
700r4
Old Jun 16, 2012 | 11:15 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: car wont start, crank
Originally Posted by 91 camaro rs
It won't even crank..
Battery only stores the power , it still has to get to the starter ( and the starter has to be working)
More info needed.
Does dash light up , do you hear any noises , clicking , etc?
Your car has VATS; have you tried a different key or cleaning your one and the contacts inside the Ign?
Have you jumped the starter to prove starter actually works?
Lots of things to consider
Old Jun 16, 2012 | 11:53 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Could be something as simple as a bad or loose battery cable or dead battery to something as aggravating as the VATS. Vetteoz is right. More info is needed
Old Jun 20, 2012 | 09:25 PM
Car: 91 rs
Engine: 305tbi
had the starter checked and it is good. all the light work as normal. there are no abnormal noises when i attempt to start the car. The gauges all "peg" ( go to the right) as they normally do. Ive tried both keys that i have and nothing changes.
bryan623
Mar 22, 2021 06:43 PM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
mizz0313
Aug 12, 2015 06:45 AM
92projectcamaro
Aug 6, 2015 01:20 PM
