84 305 4bbl wont start
Old Jun 18, 2012 | 12:21 PM
Cody302's Avatar
Car: 1984 Camaro Berlinetta
Engine: Chevy 305 4bb
ive got an 84 camaro with a 305 and a 4 barrel carburetor that wont start.
Its getting fuel and spark, the engine turns over but the car wont start.
Anybody know what the cause could be?
Old Jun 18, 2012 | 05:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
To run, an engine need air, fuel, compression, and spark, in the right amounts at the right time.
So, you either aren't getting a proper air/fuel ratio, or you don't have sufficient compression, or the spark is weak, or the spark isn't getting there at the right time.
Old Jun 18, 2012 | 09:41 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Re: 84 305 4bbl wont start
Is it backfiring through the carb or out the exhaust? When turning over does it do anything?
Old Jul 30, 2012 | 09:59 AM
Cody302's Avatar
it backfire and shoots smoke up through the carburetor
Old Jul 30, 2012 | 11:15 AM
Richboll's Avatar
Engine: 305 TBI
It sounds like the spark and fuel are getting together, just not at the right time. Have you done anything recently with the distributor cap, rotor,or wires? Check to make sure that the base is still clamped and hasn't turned. Check the inside of the cap and rotor for arcing, cracks, moisture or some other visible problem.If you don't find anything then the problem is probably a little deeper in the motor.
Old Jul 30, 2012 | 11:28 AM
Cody302's Avatar
I recently replaced the cap, rotor, coil and spark plugs
Old Jul 30, 2012 | 02:19 PM
Richboll's Avatar
Engine: 305 TBI
Sounds like you may have the wrong firing order. your wires should be on the cap and go to plugs 1-8-4-3-6-5-7-2 in a clock-wise rotation. No 1 wire should be toward the front of the engine somewhere around the 6:00/6:30 position. Drivers side is odd numbered from the front of the engine and pass side is even. If you didn't loosen the dist., this should be no problem.
Old Jul 30, 2012 | 04:54 PM
Zig's Avatar
Zig
Car: 91 Z28 with 64,000 miles
Old Jan 4, 2013 | 12:04 AM
Cody302's Avatar
I've got fuel, spark, air and compression. the engine turns over but it doesnt start
Old Jan 4, 2013 | 12:08 AM
hondastyle's Avatar
Car: Honda Accord
Transmission: 5spd
Start with what was changed before the issue. if you changed cap, sparks, and wires I would say check your firing order from the cap make sure you have the order right and if you pulled the dizzy at all make sure it is aligned right as well.
Old Jun 21, 2013 | 10:41 AM
Cody302's Avatar
I can't get the tach above 170
Old Jun 21, 2013 | 11:08 AM
Richboll's Avatar
Engine: 305 TBI
I'm not sure what that is supposed to mean....
Old Jun 21, 2013 | 12:55 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
I just want to see how this turns out...
Jake_92RS
Jan 28, 2020 10:37 PM
86IROC112
Aug 17, 2015 02:00 PM
Dquickshift
Aug 12, 2015 06:21 PM
drathaar907
Aug 6, 2015 04:20 PM
