305 help distributor issues
Old Jun 22, 2012 | 10:37 AM
Camman9167's Avatar
Car: 1991 Camaro RS
Engine: 305 Small Block
Axle/Gears: Factory
Has anyone had a hei module on the distributor go up? what symptoms would it cause, i have a suspicion that is whats wrong with mine
Old Jun 22, 2012 | 11:19 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 305 help distributor issues
Misfire at high-RPM, misfire or cutting out when hot which resolves itself after cooling down, no spark...
Old Jun 22, 2012 | 06:34 PM
Camman9167's Avatar
Car: 1991 Camaro RS
Axle/Gears: Factory
That describes my troubles perfectly lol should I attempt a new module or a whole new distributor? Which would be be easier and or better?
Old Jun 22, 2012 | 06:41 PM
KrazyFirst's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: WC t5
Axle/Gears: Stock
I think autozone tests modules for free, also check wires, coil, cap + rotor, spark plugs first, its free to check and cheaper to replace. Also, my coil on my s10 truck had a crack in it and it would act like your describing when it rained or was humid out. Don't spend your money right away.
And changing the icm would be easier than changing the whole distributor. It just some wires and bolts to get to it. Good luck!
Old Jun 22, 2012 | 07:36 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Krazyfirst that engine compartment looks sweet.
Old Jun 22, 2012 | 08:09 PM
KrazyFirst's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: WC t5
Axle/Gears: Stock
Thanks, it still needs some work, the inner fenders need painting, the accessories will be polished, and new or I might repaint the valve covers. But thank you very much!
Old Jun 22, 2012 | 09:05 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
to just replace the module is by far the easy and cheap way out . be sure to use the grease supplied . it acts as a heat sink/transfer , without it new module will last real fast . good luck .
Old Jun 23, 2012 | 08:04 AM
Camman9167's Avatar
Car: 1991 Camaro RS
Axle/Gears: Factory
Thanks guys for all your help i will try the module next, everything else is new so that is the only thing left to go bad i guess lol just hope it fixes it cause i wanna drive! i just swapped a 5 speed and put headers on it so it should be nice if itll stop misfiring haha
Old Oct 2, 2012 | 08:09 PM
VMIROC-Z's Avatar
Im having similar issues with my new set up.. new 383 with new stand alone ecm. it drives smooth until it hits about 2,000 rpms or higher it cuts out for a second and comes back. it does continuously if i stay on the gas. if i let goand stay under 2,000 rpm it drives normal. any ides cuz im stompped???????? if so could u message me for info or details thanks..
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
jklein337
Sep 19, 2018 06:23 PM
Jae992
Aug 27, 2015 09:07 AM
stalkier
Aug 7, 2015 04:49 AM
