86 trans am no start
Old Jun 24, 2012 | 12:02 AM
Savage388's Avatar
Car: 94 camaro z28
Engine: lt1
Transmission: 4l60e
I just purchased my first third gen, and while its a bit rough around the edges its a nice car, however its had a frustrating issue that when its sat for a while ( enough to cool down) the car wont crank, the gauges light up and everything it just wont crank. i have to put the tilt the whole way down to crank it and even then it takes a few tries do get it to fire. when its warm i still have to put the tilt the whole way down but it cranks no problem. any ideas for fixes? Its gonna be my daily for a while and i have to have it start everytime. thanks.
Old Jun 24, 2012 | 01:16 AM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Re: 86 trans am no start
Sounds like starter switch alignment
Old Jun 24, 2012 | 07:57 PM
Savage388's Avatar
Car: 94 camaro z28
Engine: lt1
Transmission: 4l60e
ok so how do i go about fixing that? do i have to pull the column apart?
Old Jun 29, 2012 | 05:00 PM
Savage388's Avatar
Car: 94 camaro z28
Engine: lt1
Transmission: 4l60e
Ok now the car wont start at all and its been in my driveway sitting for the past few days which is really frustrating. I work and really need to find a fix for it now.
Old Jun 29, 2012 | 08:10 PM
Richboll's Avatar
Engine: 305 TBI
Did you try starting it with the shifter in the neutral position? If nothing then put the E-brake on, hold the key in the start position, push forward on the shifter, then jiggle the shifter around and between gears to see if it starts. Try to start it with the wheel tilted in different positions.
I don't remember the switch position for sure and somebody will correct me if I'm wrong but I think the safety neutral switch is down on the column by the firewall.
If still nothing, you need to check voltage to the starter. Sounds like it could be a bad starter.
Old Jun 29, 2012 | 09:15 PM
imeredith's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
It sounds to me like a wire in the VATS system is broken or otherwise making weak contact.
Old Jun 30, 2012 | 01:02 AM
Savage388's Avatar
Car: 94 camaro z28
Engine: lt1
Transmission: 4l60e
Ive messed with both the shifter and clutch as far as the neutral safety switch and nothing worked. my car is an 86 so no vats to deal with. i just thought that it was weird that the car would only start with the column the whole way down to begin with.
eightsixseven
Dec 16, 2024 01:50 PM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
Bradsaundry
Aug 12, 2015 12:34 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
