Temperture Gauge Not Reading Correctly (Video Included)
Old Jun 24, 2012 | 11:30 PM
dredre08's Avatar
Car: 1986 Trans Am/1988 Camaro Iroc-Z
Engine: 305 TPI/350 TPI
Ok here is the deal guys, I just got an 88 iroc and the temp gauge on it does not read correctly, when ever I turn the car on it just simply goes all the way up to the red zone and it is constanly moving, it never stays still and give me a steady accurate reading. Ive posted a link of a video on youtube so you guys can see exactly what it's doing....... I know that the car is not overheating because it always does this soon as you turn the car on even if its been sitting overnight. It has to be a problem with the gauge.......
http://www.youtube.com/watch?v=AoFyo...ature=youtu.be
If anybody knows what could possibly cause this problem please do not hesitate to leave a comment, I really want to get this fixed.... Thanks
Old Jun 25, 2012 | 12:17 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: Temperture Gauge Not Reading Correctly (Video Included)
Gauge or sender - disconnect the sender and see if the gauge settles down.
Old Jun 25, 2012 | 07:09 AM
dredre08's Avatar
What and where is the temperture sender?
Old Jun 25, 2012 | 08:27 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
The sender is the thing that senses the coolant temperature, that the gauge reads. If I am correct, the stock location is on the driver's side (left) head, between and below plugs for cyls 1 and 3.
Pop the connector off it, see if the gauge stops flickering. If so, sender is probably fritzed, if not then it's the gauge or wiring to the gauge.
Old Jun 25, 2012 | 10:30 AM
dredre08's Avatar
O you mean the sensor itself, yea I replaced that but it was with one that wasn't new and I believe that it does stop when the connector isn't connected
Old Jul 8, 2012 | 08:32 PM
dredre08's Avatar
yea so I went out and checked it and it does stop moving like that when I disconnect it so should I just go buy a new sensor??
Old Jul 9, 2012 | 02:49 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
With the wire disconnected, the gauge should read solid zero. Ground out the wire, and the gauge should read solid over full scale.
If this is the case, the gauge and wiring to it are ok. The fault is then the connector to the sender, the sender itself, or the sender not making a solid ground connection where it screws into the head (unlikely).
Most likely the connector - plug it back in to the sender, and have someone watch the gauge while you wiggle it. See if it settles down then.
Old Jul 9, 2012 | 05:10 AM
poloaa008's Avatar
Old Jul 10, 2012 | 10:44 AM
dredre08's Avatar
I actual replaced the gauge with a couple I got from the scrapyard so I don't think it's the gauge, when you say wiring, what wiring are you referring too?
Old Jul 10, 2012 | 11:06 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
There's only one wire, the one from the sender to the gauge. Did u give it the wiggle test?
Old Jul 10, 2012 | 11:08 AM
dredre08's Avatar
Yea I wiggled it around and it seems to be doing the same thing, sometimes it would just stop wiggling and either just settle at the very top of the gauge or the very bottom but it wasn't actually reading the temp
Old Jul 10, 2012 | 12:55 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Time for a new sender.
Old Jul 22, 2012 | 04:35 PM
dredre08's Avatar
Ok I just replaced the sender with a new one from autozone and it seems to be doing the same thing... Does anybody have any other ideas what It could be??
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
toronto formula
Nov 10, 2015 06:17 AM
355sbcTPI
Aug 19, 2015 04:38 PM
