Which Gasket Set?
Old Jun 25, 2012 | 10:24 PM
Big Matt's Avatar
Car: 1984 Camaro
Engine: L69 305 HO
Transmission: T5 Borg Warner
Axle/Gears: Auburn LSD / 3.73
Which Gasket Set?
Hey guys,
I finally got around to tearing apart my 305 and I'm stuck on deciding witch gasket set I want to use to rebuild it. The engine leaked oil from just about every gasket before so I wanted to make sure I don't put in cheap gaskets. I was searching through Summit and I didn't find as many sets as I thought I would.
Here is a set I found:
http://www.summitracing.com/parts/SLP-260-1023/
I'm just wondering what people think about this set and if anyone could suggest a higher quality set that would be great.
Old Jun 25, 2012 | 11:41 PM
85Irocket's Avatar
Car: 85 Iroc
Engine: Don't have one yet.
Transmission: T-5 non wc
Axle/Gears: Disc brake 10 bolt with 373 gears
Re: Which Gasket Set?
I would make sure you got a one piece oil pan gasket and rubber valve cover gaskets. I would stay away from cork gaskets if possible. just my .02
1992 Trans Am
May 10, 2023 07:19 PM
hectre13
Sep 8, 2015 03:38 PM
NinjaNife
Aug 23, 2015 11:49 AM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
