PLEASE HELP, first time tpi swap
Old Jun 28, 2012 | 10:30 PM
Chris_89rs's Avatar
Car: 89 Camaro R.S.
Engine: LB9 5.0 (lt1 cam)full exhaust..
Transmission: WC T-5 pro5.0 shifter zoom S/s
Axle/Gears: 9 bolt, 3.27's
Where does the ignition coil go or mount to?
Does it use the intake bolts ? Where does the coil bracket mount ? I have an idea but not to sure. Pictures would be awesome
Old Jun 28, 2012 | 11:30 PM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
Re: PLEASE HELP, first time tpi swap
Coil gets mounted a few inches to the left of the distributor. Im sure google images would have several decent pics to show you, just try looking up coil on tpi, or even just TPI and it will probably have many pictures. Good luck with the conversion, let us know if you need anything else
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
