Weird Noise and car will not turn over and leackgin gas????PLZ HELP!
Old Jun 29, 2012 | 02:35 PM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
So I just switched my valve covers and put them back on there but when I tried to tunr on my car its wouldnt wanna turn over, it was real weird then wen I loked under the car it was leacking gasonline?very weird...IDk whats goinf on and I also made a video fo ti so if you could please help em I would greatly appreciate it!thanks!
http://s55.photobucket.com/albums/g1...=VIDEO0011.mp4
Old Jun 29, 2012 | 03:28 PM
imeredith's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Re: Weird Noise and car will not turn over and leackgin gas????PLZ HELP!
Do you still have the stock mechanical fuel pump down on the front of the engine? It looks like you have a cracked fuel line which was probably caused by moving it while putting on the valve covers. Those rubber lines that go to mechanical FP's go through a lot of heat cycling over the years and can get pretty brittle. Luckily, that stuff is super cheap at the parts store. Go ahead and get enough to replace all the rubber fuel lines under the hood while you're at it - it's cheap and if one went then odds are that the others aren't far behind. If you really want to do yourself a favor, pick up some new decent hose clamps as well, you'll be glad you did.
Old Jun 29, 2012 | 05:38 PM
calgutie's Avatar
Car: 1984 Z28
ok kool...but i looked under the car again and th eleack is not coming form the stock ful pump....though, although i provably will replace the fuel line though
Ghettobird52
Jul 5, 2024 11:18 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
B_Dubya
Aug 26, 2015 05:09 PM
BrianI
Aug 9, 2015 11:52 AM
