fuel problem still
Old Jun 30, 2012 | 05:34 PM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
fuel problem still
Running an 87 GTA 350 TPI auto using EBL 255 LPH Walbro pump, hot wire to pump from batt, removed all evap system and AIR system, a new aeromotive regulator set at 45 psi new injectors and filter.
Problem Im having is the fuel lines are pulsing like a none consistant flow of fuel which is causing the engine to surge at idle till it sometimes dies.
Fuel pressure holds for a few mins after the car is off but drops to around 20 psi and holds.
I still have an issue of fuel pressure dropping after running the car for a while and have to add fuel manually to stop surging.
I have tried pluging the evap line and it builds pressure in the tank, the breather vent on the drivers side allows air both ways but with some force. ( probably not good)
Up till now I have been running the car with the evap line open with no difference except building pressure in the tank.
Is the tank suppost to be pressurized and has anyone experienced this before?
Any ideas please?
Old Jun 30, 2012 | 08:05 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: fuel problem still
Yes, but you removed the evap system. Why? Get a new vent valve.
Old Jun 30, 2012 | 09:32 PM
transamice's Avatar
Car: 87 GTA t-top
I still have it but which part is the valve, is it on the canister itself or the part that has a bunch of hoses connected to it?
Is there a link to a picture of the valve and which part connects to the line from the fuel tank.
I removed it a while back, kept it just in case.
Even so the pulsing in the lines is a concern but I will hook it up tomorrow to get that out of the way.
Should I consider a dorman fuel pump pulsator?
Old Jun 30, 2012 | 09:41 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
In the rear, where the sway bar end link attaches to the sub-frame rail, on the driver's side, there is a plastic thing on a hose. That is a one-way valve. It is supposed to let fresh air in, but not let gasoline vapors out. The vapors are supposed to be stored in the charcoal cannister until the computer signals another valve to let the engine's vacuum draw those fuel vapors into the intake manifold to be burned. This is the evap system, and while it may not look sexy, it only adds about 2 pounds to the car, and doesn't hurt power, MPG or handling. Removing it creates hassles. That cannister has a replaceable filter on the bottom, and that needs replaced, but nobody ever does unless they fail a Cali emissions test.
Old Jul 1, 2012 | 02:24 AM
transamice's Avatar
Car: 87 GTA t-top
Where do I buy a new one way valve or what is the proper name for it if I were to ask for one at a parts store or dealership?
Is there a part number?
Old Jul 1, 2012 | 10:19 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I don't know. I just checked RockAuto.com, '87 'bird 5.7L, not listed in emissions or fuel categories.
Old Jul 2, 2012 | 01:45 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Have you monitored the fuel press while eng is surging? It would have to change a lot to cause surging at idle. I have an adjustable fuel press regulator and I've adjusted it down to 25-30 psi without any change to idle quality (and very little change to the BLMs). I normally run 42 PSI with vac hose connected.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
