Lack of power.
Old Jul 1, 2012 | 03:09 PM
stubby1962's Avatar
Car: 1989 IROC-Z
Lack of power.
Hi All..
I have an 89 IROC with the 305 TPI. The car really lacks on power. Especially take off. Buts goes pretty good when the RPM's get up.
I have changed the plugs and wires. Set the timing at 6 BTDC. Still no difference. I ran the car to normal temp and disconnected the brownish wire and set the timing and reconnected the wire. Should I disconnect the wire then start the car and set the base timing and then connect wire or does it make a difference? That is the only thing I can think that I may have done.
Also could I move the timing to 8 BTDC and try and possibly to 10 if it makes it run better.. Thank You for all your replies in advance...God Bless US All...John
Old Jul 7, 2012 | 04:04 PM
stubby1962's Avatar
Car: 1989 IROC-Z
Re: Lack of power.
OK.. After running it through my head a few days. I reset the timing to 8* BTDC..Runs great now.. I set the timing before by the sticker under the hood which said 6* BTDC..It's simply amazing what 2* on the timing would make..Runs like a new one..
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
cheesehomer
Dec 31, 2015 08:48 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
lanceflame44
Sep 25, 2015 12:28 PM
