Power balance test results
Old Jul 1, 2012 | 10:26 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
I have been troubleshooting a fuel trim issue for the past week, although it has been an issue for years. I decided to run a power balance test, here are the results of three runs averaged. The results are change in engine RPM from reference.
#1 - 107%
#2 - 104%
#3 - 95%
#4 - 92%
#5 - 93%
#6 - 95%
Cylinders 3-6 look normal, 1 and 2 have me stumped. What would cause RPM to increase when disabling an injector? Thanks for any input.
Old Jul 2, 2012 | 12:19 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Re: Power balance test results
Do you have any ALDL data?
Is the IAC disconnected for the test?
Does the ign timing change any during the testing?
Could knock counts be pulling some timing when testing cyls 3-8?
Significant difference in inj resistance from 1/2 compared to the rest?
BRoss99
Aug 10, 2025 05:08 PM
midge54
Dec 27, 2019 04:14 PM
sailtexas186548
Aug 24, 2015 10:11 PM
InfinityShade
Aug 22, 2015 08:00 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
