No Start
Old Jul 7, 2012 | 03:19 PM
idleminded's Avatar
Car: 89 iroc-z28 vert
Engine: 305 v8
No Start
I bought my 89' i-roc z vert about six months ago and haven't had any problems with it up until now.The engine is the original one and has 63xxx miles on it. I decided to drive it into work one day and when I was leaving to go home the engine wouldn't turn over. Myself and a couple of buddies changed out the distributer, the ignition coil, and the ignition module to see if the engine would turn over. The last thing we had canged was the coil and then it finally turned over. We let it run for a few minutes and it seemed fine. I didn't get a mile down the road before the engine just shut off. After it shut off, I tried to restart it and it had knocked a couple of times and started shuddering and wouldn't turn over again.
If anyone has any advice or ideas on what could be causing the issue please let me know. Thanks
Old Jul 9, 2012 | 09:04 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Re: vert trouble
Not a convertible issue. You may get more help from one of the other boards.
Good luck troubleshooting.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
