1984 trans am prob
Old Jul 7, 2012 | 09:05 PM
bypass-21's Avatar
Car: 1984 Trans Am
Engine: 305 cui
1984 trans am prob
hello everyone,
i recently bought this 1984 trans am and right away fired it up, the car began to seriously shake, i thought the car might be warming up or just plain low idle, easy fix right? well over time the idle began to get really crazy, like starting it and it would be at 1,000 RPM or like today it would roughly be at 2,000 RPM. and every time the tachometer needle would bounce around slightly. to make matters worse one day i fired the engine up to try to see if the idle fixed itself and the car made a loud slapping sound, fearing for the engine i shut it down and opened the hood to discover the belt to the altinaitor had poped off and wrapped itself around the cooling pump fan! luckily i noticed no damage to the car, my fear was the crank shaft pulleys doing, (which has had a slight wobble since i got it and goes away when the engine revs higher) so now my fear is that there may be some serious damage caused by the harmonic balancer. so i wanted to know if 1 any one has had this problem with the shaking and the idle and how they fixed it. and 2 of any one knows how long the engine has to run with a bad harmonic balancer to do damage and f a dealer can fix it and for how much it usually costs to fix
i belive i have a 305 engine under the hood, and it has a carb intake and a water pump driven fan and a has a CEL
-Thanks guys for any help!
Jorlain
Aug 24, 2022 05:11 PM
colton_carlson
Mar 8, 2019 12:21 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
suzuki949
Aug 28, 2015 08:07 AM
