Grounding out
Old Jul 10, 2012 | 07:39 AM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
Grounding out
So this past monday I finished my swap and hook everything back up but when I go to connect my positive terminal it sparks cause its grounding out. I found where its coming from and its the starter. I looked all through the starter area and changed wires around to see why its happening but with no luck
Old Jul 10, 2012 | 08:01 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Grounding out
First of all, when hooking up a battery, the last connection should ALWAYS be the negative terminal at the battery.
In your case, do you suspect the positive cable might have the insulustion rubbed through somewhere? It's a hell of a long cable on these cars.
Old Jul 10, 2012 | 08:16 AM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
Re: Grounding out
Well I know there's a bare spot on the power cable to the spark coil but its covered up. If the starter casing would touch the block would that ground it out?
Old Jul 11, 2012 | 06:45 AM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
Re: Grounding out
I found the problem, had the battery to starter cable hooked up to the heat shield bolt Haha. Now my key wont crank the enginover, I gotta use a vu.o switch to start it
$750 L98
Feb 1, 2025 02:25 PM
Falcon50
Aug 22, 2020 03:26 PM
Thaney9
Oct 15, 2015 06:37 AM
lewandom
Oct 1, 2015 08:15 AM
