1983 Z-28 Leaks
Old Jul 10, 2012 | 07:56 PM
tooltime's Avatar
Car: 1992 RS Polo Green Coupe 86 IROC
Engine: 305 TBI
Transmission: Automatic
Axle/Gears: Yes it has some!!!
1983 Z-28 Leaks
Hey guys and gals. I have just started on my 83 Z28 and have been fixing things as I see them. The list is long and I have started on the engine bay. The power stearing is leaking where the stearing shaft goes into the cast stearing gear housing. Looks like a pain in the butt to try to fix....am I looking at a rebuild or a replace thing here. I have plenty of ability, can the seals be replaced on the housing or is it just easier to replace? I'm just getting started with this car and don't know much about avaiblity of parts. Thanks for your help. Matt
Old Jul 10, 2012 | 07:59 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: 1983 Z-28 Leaks
easier to replace the pump but yes, the seals can be replaced.
Old Jul 10, 2012 | 08:33 PM
tooltime's Avatar
Engine: 305 TBI
Re: 1983 Z-28 Leaks
It's not the pump itself that is leaking. The pump has a hose that comes out of it, and goes to the gear box. I think I'm calling it by the correct name. The stearing wheel shaft goes into it. Where the shaft goes in, it has a u joint connection and then into the cast case. It's leaking where the shaft goes into the case. I would assume that it's easier to pull the gear box out and work on it over a bench. Let me know if I'm out of line here or not. Thanks for your quick response. Matt
Old Jul 10, 2012 | 10:30 PM
Re: 1983 Z-28 Leaks
Yup, piece o cake to work on it on the bench. I've done several, no problems except for being careless and letting the ***** fall out and go everywhere and losing them, when I tear em down.
Go for it, you'll be glad you did.
ZEEYAA
Apr 16, 2023 08:29 PM
Reid Fleming
Oct 10, 2015 09:56 PM
lewandom
Oct 1, 2015 08:15 AM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
