Anyone with knowledge on cams?
Old Jul 5, 2012 | 08:41 PM
Jfinnkma91's Avatar
Car: 1984 Chevy Camaro
Axle/Gears: 7.5in 10 bolt with 3.08
Ok I'm rebuilding a 305 engine I have as a spare. I won't to give it noticeable power and torque. I'm getting the heads machined down to around 62-60cc. I have no clue what the duration of the cam should be for intake/exhaust. Any suggestion?
Old Jul 5, 2012 | 08:58 PM
blue birdy 87's Avatar
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
Re: Anyone with knowledge on cams?
Lt4 hotcam or lt1 cam is the popular choice.
Old Jul 5, 2012 | 09:03 PM
Jfinnkma91's Avatar
Yea but they're popular because of the idle they make. I'm trying to get good torque and decent horsepower.
Old Jul 10, 2012 | 12:33 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
The Hotcam is a poor choice for a 305 unless you don't care about low rpm power.
Is this a roller cam motor? If so, the LT1 cam mentioned , especially the one from the B-Body, will give excellent torque and good power to 5500 rpm.
Unless your application is intended more for strip than street, with serious gearing and converter, I'd limit intake duration to about 210 @ .050" and exhaust to 220.
The GM ZZ3/ZZ4 roller cam (208/221/112) would work well, slightly less low rpm torque than the LT1 cams, but would extend the power curve to near 6000 rpm.
Old Jul 10, 2012 | 12:47 PM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
I'm going to be putting this into my 305 for autox and street use, it was what I found that was close to mw66nova's (someone who has done amazing things with the 305) recommendation.
Edit: You need new valvetrain for this cam, I'm just sharing it to give you an idea.
Old Jul 10, 2012 | 10:40 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
How can you guys be posting anything when we don't even know yet what casting number of heads the OP wants to use? Not stock 305 heads, since those start out around 58 cc, so can't be milled to 60-62 cc.
Old Jul 10, 2012 | 11:11 PM
Dakota W.'s Avatar
Because he asked for a suggestion, not the exact camshaft he should be using.
Old Jul 11, 2012 | 12:00 AM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Figure out what you have first, then call one of the cam companies instead. Asking for advice for camshafts on this forum is like punching yourself in the nuts. Talk to someone reputable that REALLY knows their stuff, and not just another salesman from Comp or Jegs.
Jorlain
Oct 8, 2015 01:57 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Glowsock
Sep 6, 2015 06:40 AM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
