fan wont turn on
Old Jul 15, 2012 | 11:06 AM
maro3rdgen's Avatar
Car: 1989 camaro RS convertible
Engine: 305 TBI stock
Transmission: 700-r4
fan wont turn on
alright so here is my problem. car has been running good but coming home last night i noticed my temperature gauge was really high, almost to the red line, so i pulled over popped the hood and noticed my fan wasn't running. any ideas on what may be the problem. thanks in advance
Old Jul 15, 2012 | 11:15 AM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Re: fan wont turn on
You probably have a burned out relay. I had the same problem awhile back.
Old Jul 15, 2012 | 12:11 PM
maro3rdgen's Avatar
alright so dumb question here. where is this relay located at? i cant find it for the life of me
Old Jul 15, 2012 | 12:36 PM
It's on the drivers side firewall. look for a green w/white stripe wire below leading to it.
Old Jul 15, 2012 | 01:11 PM
maro3rdgen's Avatar
Thanks but I'm still lost...I see no relay switches and no green with white wire
Old Jul 15, 2012 | 02:24 PM
The relay doesn't look like a typical switch. Either it's rectangular, or oval/rectangular depending on the year. I recommend going to a parts store and having them show you one. A knowledgeable parts guy may know exactly where it is on your car. You need to look under the socket the relay plugs into to see the green w/white wire.
Old Jul 16, 2012 | 07:57 PM
maro3rdgen's Avatar
Well I replaced the relay and fan still doesn't turn on...does this mean the fan needs to b replaced?
Old Jul 16, 2012 | 08:13 PM
Try grounding the green/white stripe wire. If the fan comes on, the motor is still working.
RazorN8
Jan 7, 2022 11:44 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Papaginos
Sep 27, 2015 03:29 PM
bryanwood74
Sep 24, 2015 09:50 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
