Knock senor on 1970 block
Old Jul 17, 2012 | 11:21 AM
Tery114's Avatar
Car: 1991 Camaro RS
Engine: 358
I just change my motor in my camaro two days ago and I did not know I need to add so many thing to get it going. I change from a 305 TBI to a 350 bored .30 over. I kept it TBI, but I ran into problem with the block because it is a 1970s block without a knock sensor. I want to know how do I install a knock sensor on the block.
Old Jul 17, 2012 | 02:10 PM
Tery114's Avatar
Car: 1991 Camaro RS
Engine: 358
Re: Knock senor on 1970 block
It will not start, It ran well for about 10 mins and died. I bought the ECM today from a caprice 350 TBI and change the Injectors also. I was told to get the car to run right I would need to order a 350 specific knock sensor.
Old Jul 17, 2012 | 07:44 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
You do need a 350 knock sensor, the 305 sensor will not work because it's tuned for the wrong frequency. The knock sensor screws into one of the water drain holes in the block. There's one on each side, in the middle way down low. Might as well use the hole on the right side since your connector is already there.
spartanreaper
Sep 25, 2015 07:22 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
tgp1990
Sep 4, 2015 06:24 AM
