Engine surging
Old Jul 28, 2012 | 02:37 PM
tri power's Avatar
Engine surging
Help Help 90 GTA 350 tune port it is surging at idle and surging down the highway have replaced computer new distributor took tune port system off checked for intake leak cannot find anything wrong it sounds like it has a vaccum leak but cannot find one have checked fuel pressure and injectors HELP HELP.
Old Jul 28, 2012 | 03:05 PM
Zig's Avatar
Zig
Car: 91 Z28 with 64,000 miles
Re: Engine surging
It may be a vacuum leak in one of your accessories. Disconnect all the vacuum lines form the plenum (except sensors) and block them off. If it's a vacuum leak it should steady out. then reconnect one at a time to find which line has the vacuum leak. The hard plastic lines are natorious for cracking and being difficult to find. Make sure to check the brake booster hose from the plenum also.
Old Jul 28, 2012 | 09:00 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Engine surging
Reddeath210
Oct 6, 2015 08:20 AM
jbd1969
Aug 17, 2015 07:06 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
