Dowel Pins for Bellhousing Question
Old Jul 28, 2012 | 09:22 PM
88 vert guy's Avatar
Has anyone tried to remove the two 5/8" taped dowel pins at the rear face of cylinder block that the Bellhousing fits over? Is this hard to do? Any special tools needed?
Old Jul 29, 2012 | 07:48 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Dowel Pins for Bellhousing Question
What would be the reason for removing these dowels?
Old Jul 29, 2012 | 07:55 AM
Not hard; they're just a press fit.
Old Jul 29, 2012 | 07:56 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Just drive them out from the front side of the block. I've even done it in car to put offset pins in.
RBob.
{edit: sofakingdom beat me to the punch, oh, bad pun}
Old Jul 29, 2012 | 08:04 AM
I have the trans out for a clutch replacement. Getting the bellhousing off was a b***h! The dowels are rusty and want to replace them.
Does anyone know the recommended thread sealant to use on the three small oil gallery plugs above the large core plug?
Thanks!
Old Jul 29, 2012 | 08:16 AM
Yes you should use sealer. The Loctite/Permatex thread sealer product is fine.
Old Jul 29, 2012 | 09:47 AM
grumpyvette's Avatar
http://forum.grumpysperformance.com/...housing#p21690
)to get the old rusted bell housing alignment pins loose heat them with a propane torch for about 2 minutes then spray the pins with freeze spray for a minimum of 8-9 seconds with
http://www.loctitefreezeandrelease.com/
http://www.amazon.com/Loctite-Freeze.../dp/B001VXU474
http://www.summitracing.com/parts/LAK-15907/?rtype=10 they should easily twist out with vise grips or punch out with a hammer and drift. the new pins use locking expansion allen key locks, once correctly indexted
Old Jul 29, 2012 | 10:04 AM
1gary's Avatar
A home make guide for the trans on two the dowels is to long starter bolt with a the heads cut off them and a slot cut into them.Screw them in on each side and slide on the trans using them as a guide.
Frozer!!!
Jan 19, 2024 04:55 PM
gixxer92
Sep 1, 2015 04:32 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
redmaroz
Aug 16, 2015 11:40 PM
383backinblack
Aug 15, 2015 06:36 PM
