1989 tpi 350 intake bolts, HELP ME!!!!
Old Jul 29, 2012 | 06:20 PM
Vingentry's Avatar
I have a 1989 l98 350 and the intake bolt torques have managed to strip the head of the bolts out, I need to remove them, anyone got a cheap easy method to get these stubborn sobs out? They are torqued down to probably the factory 35-45 foot pounds, please contact me directly by email with information/tips, I live out in benbrook texas incase someone lives nearby with a tool for it they would let me borrow.
Old Jul 30, 2012 | 03:11 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: 1989 tpi 350 intake bolts, HELP ME!!!!
So you were tightening them down and now they just spin free? Or you were trying to take them out and they're stuck? do they turn at all or did you just round off the tops?
Old Jul 30, 2012 | 04:54 AM
Vingentry's Avatar
Was tightening them after intake gasket replacement and the t45 bit I was using striped the center out, the bit itself then twisted and broke. (snapon) so I whipped out the 'trusty' impact set, which broke (again), after striping out some more centers, I'm guessing the 23 years weakened the bolts, or something... The threads aren't stripped just the tops so I can't budge the things to put in the shiny new sensible 14mm hex head bolts.
Old Jul 30, 2012 | 03:45 PM
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
Happened to me too. Titanium tipped drill bit. The bolts are soft. So is the runner, so watch out. I used a bit the size of the bolt head. My thinking was get the head off, then screw extractor to get the rest of the bolt out.
In my case sadly I drilled not only through the bolt head but into the runner as well, ruining it (on the hard to see bolt driver side front).
So a dent free used new runner wasn't that expensive fortunately, and the rest of the bolt removed by hand so no screw extractor needed.
Hopefully someone has a more gracefull way to do it!
Frozer!!!
Jan 19, 2024 04:55 PM
okfoz
Mar 9, 2017 02:35 PM
kyleb24
Aug 15, 2015 08:24 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
