350 build up help
Old Aug 1, 2012 | 10:19 AM
jugheads88gta's Avatar
Car: 89 camaro
Engine: 68-454,87-nothing yet,88gta-305 tpi
Transmission: stock 700r4
Axle/Gears: borg warner 9-bolt/3:27 gears
350 build up help
So I pick my 350 .30 over tomorrow from getting hot tanked and new cam bearings installed. I have a stock set of vortec heads I will be changing the the springs to except 530+ lift.the only thing I have is the block and heads crank and a 600 carb.I am aiming to make as close to 450hp as I can get.now I have 6 eagle rods 6.000 I can buy 2 more for 80 bucks or I can use my stock rods cause I have all 8 already but I need pistons and I was gonna go super cheap eBay cause I was in a rush to get it done but I'm just going to do it right.what I want to know is will it benefit me to use the 6 inch rods instead of the stock 5.700 and going off that I will decide what pistons to use.I have more questions but those will come as i go.
Old Aug 1, 2012 | 10:46 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: 350 build up help
You lost me at, "and 600 carb". haha good luck with your build
Old Aug 1, 2012 | 11:03 AM
Car: 89 camaro
My bad. I just need to know should I use the 6 inch rods instead of the stock rods which will benefit me most? The pistons I found to work with 6 inch rods and a stock crank were a bit more expensive but if it's worth it I will spend the money but what is the point in using 6inch rods?
Jake_92RS
Jan 28, 2020 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
Eric-86sc
Aug 24, 2015 09:01 PM
NWAsonoma
Aug 18, 2015 05:45 PM
sreZ28
Aug 14, 2015 07:48 PM
