MAP Sensor Replacement 1985 Pontaic Firebird
Old Aug 1, 2012 | 04:31 PM
stanleyN's Avatar
I have a 1985 Pontiac Firebird 2.8L V6 and it idles very poorly it also has a CEL and I scanned it and the code is 32 so I bought a MAP sensor but the problem is I cannot locate it..I can find the mass air flow sensor but not the MAP Sensor..please help.
Old Aug 1, 2012 | 04:46 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: MAP Sensor Replacement 1985 Pontaic Firebird
Code 32 is EGR Failure. It means that either the EGR is not opening as it should, is open when it shouldn't be, or that the EGR temp sensor is faulty. Codes 33 & 34 are MAF or MAP sensor codes, depending on what the vehicle is equipped with. Your car is an OBDI MAF car. It doesn't have a MAP sensor.
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
92camaroJoe
Aug 13, 2015 06:07 AM
squiggy2
Aug 9, 2015 09:30 PM
