Vibrates in drive at idle
Old Aug 5, 2012 | 09:51 PM
acdcfan37's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Axle/Gears: Open Diff
I have a 1991 RS with the 305 and just lately when im in gear waiting at a light right when my car hits 800 rpm you can feel the whole car shaking. The engines not missing but its a steady shake. Any ideas?
Ryan
Old Aug 6, 2012 | 12:49 AM
Toops's Avatar
Car: '86 Iroc-Z Camaro
Engine: 454 punched out to a 468
Transmission: 350 Turbo
Axle/Gears: Gear set to 3.73
Re: Vibrates in drive at idle
Check your spark plugs and wires. A cylinder probably isn't firing. That would be your first step.
Step two would be to check the compression in your cylinders. If it isn't a plug/wire, then it might be a compression issue.
Old Aug 7, 2012 | 12:22 AM
newagereject's Avatar
Car: 1988 Trans Am GTA
Axle/Gears: 3.73 posi
I'm having the same problem the vibration goes away if i give it a little gas
Old Aug 7, 2012 | 02:18 AM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Ryan
I had a similar problem like this in my case it turned out to be a broken rocker arm stud
Old Aug 7, 2012 | 03:37 AM
brando54009's Avatar
Car: 82 firebird
Engine: a few
Transmission: th350
Axle/Gears: wondering this myself
is it enough to shake the whole car or is it just a little vibration that you notice in the pedals? it doesn't do it at any other time at all? what does it sound like when it does it? does it tap or knock at all or even rattle
Old Jan 13, 2015 | 07:19 AM
1990bandit's Avatar
Car: 1990 transam gta
Engine: 305 soon to be 383 stroker
Axle/Gears: 3\23 9bolt
I am having the same problem same engine. At idle and park around 800 rpm it shakes the entire car. At 700 and 900 rpm it's fine. 1990 trans am gta
Old Apr 1, 2015 | 11:10 PM
blackfrontier's Avatar
Car: 89 GTA & 76 T/A
Engine: 5.7/455
Transmission: GTA Auto/76 T/A 4speed
I recently noticed a pulsing vibration that just started in my 89 GTA that only does it at idle and in gear. If I come to a stop I can deal a pulsing vibration that makes various parts of the car rattle. It isn't super bad but annoying so I put it in neutral and it goes away. The engine was rebuild 6 months ago at a GM dealer and has new injectors. Transmission was also rebuilt so not sure if it's exhaust touching or something else? I also had new motor mounts installed when engine was out.
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
db057
Aug 22, 2015 08:17 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
