WTF DID I DO-- HE IS DEAD JIM !!!
Old Aug 5, 2012 | 11:08 PM
MY-92-RS's Avatar
Car: 92 CAMARO RALLY SPORT
Engine: 383 sbc w/250 shot of nitrous
Transmission: AMERICAN POWERTRAIN- EXTREME TKX
Axle/Gears: STRANGE ENG. 12 BOLT 3:90 SPOOL
oil pressure was kinda low so I got a mechanical oil pressure gauge to confirm malfunction .. yep oil pressure low .. like 13 psi at idle .. 42 at 2000 rpm 65 3500 rpm not good -- Change engine oil drain - royal purple 10W30 out opened up oil filter found nothing no metal .. fill with royal purple 15w40 . prime fill filter ... crank engine till I get oil pressure ...GUESS WHAT ENGINE WILL NOT BUILD ANY OIL PRESSURE AT ALL BEEN SPINNING THE CRAP OUT OF IT !! both gauges read (000000000) time for new engine AGAIN !!!! .....
Tell you what Melling can do with their (P.O.S.) Oil pump !!
Old Aug 5, 2012 | 11:30 PM
project89's Avatar
Re: WTF DID I DO-- HE IS DEAD JIM !!!
make sure the pickup didnt fall off the pump.
i take it that this isnt the stock engine, did u weld the pickup to the pump?
did u replace the stock oil pump driveshaft when it was put together
Old Aug 6, 2012 | 10:34 AM
85Z28383's Avatar
I feel compelled to ask, how do you figure those numbers were low. How much pressure do you want?
Old Aug 6, 2012 | 10:50 AM
Dark Ember's Avatar
Car: 90' Firebird Formula 350
I concur, my 4.3L S-10 has oil pressure very similar, almost identical in fact, to those numbers. I don't like how low it is at idle, but the truck has run great for 80k miles thus far with those numbers. I should mention however that I am not sure of the psi during cranking. I would expect at least 1-2psi myself, but I cannot confirm right now. I'll go crank up my truck while watching the gauge and get back to you on that. If you want more pressure you can upgrade to a new pump, but don't upgrade just because you think those numbers are low.
P.S. love the star trek reference :P
Old Aug 6, 2012 | 12:11 PM
blackbeauty89's Avatar
Car: 1989 Pontiac GTA/2007 TrailblazerSS
Engine: 350 L98/LS2
Transmission: 700-R4/4L70E
Axle/Gears: 3.27/4.10
Oil pressure seems normal to me. That's what my 350 runs at about.
Old Aug 7, 2012 | 05:27 PM
MY-92-RS's Avatar
normal oil pressure for this motor has been about 29 at idle 60+ 2 grand and up this motor only has maybe 5k at most on it while cranking normal get pressure to gauges no problem
so today pulled dist hooked up drill got 73 psi... now what ... can the oil pump drive shaft disconnect/misalignment with oil pump on its own ???
yess I was born a Trekker
92projectcamaro
Sep 29, 2015 07:07 PM
raymondandretti
Sep 27, 2015 06:43 PM
BOOT77
Sep 16, 2015 08:37 PM
gta892000
Sep 16, 2015 12:37 AM
