Rubber fuel lines
Old Aug 8, 2012 | 03:59 PM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
Rubber fuel lines
Has anyone experienced collapsed rubber lines that connect from the main lines to the rail lines on a 1985-1992 Firebird 350 TPI?
Are these lines still available through GM dealers?
Old Aug 8, 2012 | 04:10 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: Rubber fuel lines
I have experienced collapsed rubber hoses, both brake hoses and fuel hoses, in a few cases. They can be tricky to pinpoint and often lead to misdiagnosis of the fuel pump. I don't know if GM offers the hoses, but I doubt it. Of course it doesn't hurt to ask at a dealership parts department. Otherwise, you can make replacements using several different types of high pressure hose, including braided hose, and fittings from Russell or Aeroquip to name just two options. They both make the GM o-ring hose fittings. Oh, and another option is your local rubber supply. Here in Portland we have Premier Rubber where they will rebuild any hose, using your fittings, and crimping them onto new hose that is superior to the original, making an exact copy of the failed part. The cost is very reasonable too.
Old Aug 8, 2012 | 04:50 PM
transamice's Avatar
Car: 87 GTA t-top
Thanks for the reply, I am on my 5th fuel pump trying to figure out my fuel pressure loss syptom after 20 min driving.
When I prime (override the relay) the fuel lines it sounds like it takes 5-8 sec to fill the line, like its clogged somewhere.
With a brand new fuel pump metal lines in good condition, new injectors, filter, regulator and a pulsating feeling at the lines when the engine is running the only weak link could be 25 year old rubber lines that have crapped out internally.
Just another thing to try.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
