Engine light comes on only at hwy speeds?
Old Aug 9, 2012 | 05:19 PM
88PontiacT/A's Avatar
Car: 88 T/A. TOTALLED!! (not by me)
Engine: TPI 5.0
Transmission: 700r4 Auto
Axle/Gears: 2.73 posi
When driving under 65-75 mph the light never turns on , but when on the highway, cruising to the next town (about 10 miles away) at ~70-75mph the light will come on. After the car is driven at slower speeds for a while, or parked and turned off and then re-started, the light will go off and doesn't come back on until the car is driven at highway speeds again. Car is running fine, coolant level and temp is good, battery voltage is good, oil pressure is good, etc. Any ideas what could cause this issue?
Thanks,
John C.
Old Aug 9, 2012 | 06:12 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Engine light comes on only at hwy speeds?
32 ?
Old Aug 9, 2012 | 08:05 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Get a flash code. Best guess is the o2 sensor but that's throwing a dart at a board withing having some diagnostic information.
Old Aug 9, 2012 | 08:30 PM
camarorookie's Avatar
Thanks,
John C.
My 88 does this only at or faster than 75mph. My cylinder temp was too high and the egr test circuit was picking this up and throwing a soft code. I changed my thermostat to a 180 and no more light.
I drove 1600 miles straight through to East Texas with the stock 195 thermostat and the damn light came on after every stop. I drove back with the 180 thermostat and never saw the light.
Old Aug 9, 2012 | 08:38 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
I'm going to bet it's the ol' EGR code thing. There was a thread around here some where about EGR temperature or some such thing. It's been a while I don't remember exactly.
Old Aug 9, 2012 | 11:26 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
My 88 was doing this when I got it in April this year. EGR wouldn't hold vacuum. Replaced the EGR and haven't had a light come on since. But it was throwing the EGR code.
Old Aug 10, 2012 | 01:02 AM
Engine: TPI 5.0
Ok, so where can I find info here that tells how to pull the codes? And does the light have to be still on, or will it be stored? It's OBD1 right? Don't think the prob is temp related because the car runs pretty cool as long it's not putting around or idling a lot. Could be tho. Car has 135K+ miles, and I don't know if the o2 sensor(s) have ever been replaced so ti could be that too. If it's egr can I just remove it (egr valve) and block it off? Car doesn't have to pass smog anymore here and has no catalytic and a 3" flowmaster cat-back as its only mods. Otherwise it's stock.
John C.
Old Aug 10, 2012 | 11:42 AM
Engine: Lb9
Transmission: M20
http://www.theimportkiller.com/forum...hp?topic=420.0
Old Aug 11, 2012 | 03:24 PM
Engine: TPI 5.0
Thanks!
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
