Is it time for a heated 02 sensor?
Old Aug 12, 2012 | 10:16 AM
Untamed Z's Avatar
It is a mild built 383 stroker, D port Aluminum heads, SLP 1.75" shortys, with the one wire 02 sensor in the collector. It flows considerably better than the stock exhaust manifolds, so I'm wondering if my 02 readings could be inaccurate, possibly not heating up to 600*. Experiencing a rich condition. Fuel burns nice and clean when you ease into the throttle, but its overly rich when you stomp it and also when you let off the throttle after a hard pull it will smoke unburnt fuel for about 3 seconds, then go back to pretty much normal. Also seeing a whisp of unburnt fuel while idling, but not too bad.
Anyone had any similar problems, and could the heated 02 sensor potentially cure the issue? I know these old ECM's (7165) weren't the best, but the mods to the engine are pretty mild.
Old Aug 12, 2012 | 12:39 PM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
Re: Is it time for a heated 02 sensor?
Not saying a heated 02 wouldn't be a good idea with headers but at WOT the 02 sensor does nothing as the computer runs off a predetermined fuel map (open loop). The 02 sensor is mainly used for cruising fuel trim (closed loop).
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
More power equals more heat. Running carb tpi tbi?
Old Aug 12, 2012 | 01:18 PM
Untamed Z's Avatar
It has a Super Ram, 26#ers, 58MM.
Old Aug 13, 2012 | 08:28 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by Untamed Z
SLP 1.75" shortys, so I'm wondering if my 02 readings could be inaccurate, possibly not heating up to 600*.
Doubt it.
I had a unheated O2 sensor on the collector on my long tube headers and it only dropped out ( cooled off ) when car was at idle.
As soon as I drove off it heated up and came back on line
Has ECM been tuned for the mods?
Old Aug 13, 2012 | 09:01 PM
Untamed Z's Avatar
Yes, the ECM has been tuned for the mods. Tomorrow I am going to try a brand new 1 wire sensor, and see how things work out. 02 sensors have a habit of getting lazy as they get used, so I'm a little hopeful. If that doesn't work out, next step will be installing a heated sensor. I will keep all informed.
Thanks.
Old Aug 14, 2012 | 05:34 AM
Cat Amanigh's Avatar
Car: 91 RS
Engine: 305 topped w/ Summit Holley Clone
Transmission: 700R4, a placeholder for that T-56
Axle/Gears: 7 5/8, 2.73
If it was my car, I'd break out the torch and multimeter to find out for sure if the sensor is lazy, but I'm mostly broke from my relationship with my car, and propane is cheaper than a new sensor. Either way, I wish you best of luck.
eightsixseven
Dec 16, 2024 01:50 PM
9192camaro
16
Feb 3, 2019 12:21 AM
kyle5647
Aug 15, 2015 11:56 PM
fonzie85
Aug 13, 2015 11:50 AM
