WTF.. CAR WONT START.?
Old Aug 12, 2012 | 03:56 PM
88 Z-ROC's Avatar
Car: 88 IROC-Z (L98)
Engine: Edel. Lwr, SLP Rnrs, Ported Plenum
Transmission: 700R, 2800 Stall
Axle/Gears: 3:42 Posi.(4th gen.) UMI R/Susp.
Installed the high flow intake and car started up.. Had a bit of a misfire but i figured it needed some adjustment on the distributor.. It was late so i left it alone
Came back the following day put the car in gear and it shut off.. Tried to adjust the timing and now car wont start.. It looks like it wants to but loses gas..
So i checked the injectors and none of them are pulsating.. I checked the fuel pump and it turns on.. disconnected the fuel lines and have gas there... I checked the injector harness with my probe and got a positive feed on both wires..
Now I'm stuck, what could it be.?
Old Aug 12, 2012 | 04:53 PM
88 Z-ROC's Avatar
Re: WTF.. CAR WONT START.?
any help would be appreciated
Old Aug 12, 2012 | 04:57 PM
Vader's Avatar
No injector pulses? Make sure the distributor wiring is intact.
Old Aug 12, 2012 | 06:11 PM
L98IROCZ1987's Avatar
Car: 1987 IROC-Z Z28
Axle/Gears: 3.70 9 bolt
Are you sure it isnt flooded, also make sure you dont have any vaccum leaks
Old Aug 12, 2012 | 06:14 PM
Also make sure your distributor rotor is pointing to cylinder one on cap when cylinder one is at top dead center on compression stroke.
Old Aug 12, 2012 | 07:33 PM
88 Z-ROC's Avatar
why do the injector leads both read positive with the key on..?
I had a mechanic check out my timing and said it was off and the #1 point on distributor is towards the fire wall.. (I thought that was weird) But no luck..
Im gonna dbl check the dist. wiring. tomorrow and make sure the inj. are not flooded..
Old Aug 14, 2012 | 12:07 AM
88 Z-ROC's Avatar
After replacing count less parts. lol I figured out it was a fuse. In my defense it was checked, not by me but it was "checked"
I am able to turn it on but still have to accelerate it so that it stays on..?
Once at a higher rpm it seems fine but my tach doesn't function so I don't know how high it is.
Old Aug 14, 2012 | 12:25 AM
yo soy el warg's Avatar
What fuse did you replace? I'm having the same problems you had.
Old Aug 14, 2012 | 01:08 AM
Tazzmo's Avatar
Did you unplug the brown wire next to the blower motor? This is required to set the timing on my 91. Should be the same on yours. The computer will not accept the timing changes with it plugged in.
Old Aug 14, 2012 | 09:33 AM
88 Z-ROC's Avatar
@ yo soy... I changed the injector fuse #1 under the column.. there are 2, one for each side.
@ tazzmo... No I haven't, wasn't even aware of that.. Thank you.. will try today..
Old Aug 15, 2012 | 10:27 PM
88 Z-ROC's Avatar
I am at wits end w/ my girl.. It seems for every problem I solve another comes..
She is now throwing a code 43.. I also believe I have a vac leak.. I have white smoke coming out of the engine when I start it.. (simple intake change) It sounds like the egr is hissing/knocking..
I have no idea why or how I got a code 43..? getting frustrated at this whole ordeal..
Old Aug 16, 2012 | 07:11 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Check your knock sensor wiring. This code means that the wire from the sensor to the ESC module is open or shorted to ground or power, or that there is a problem with the module or sensor.
Old Aug 22, 2012 | 08:36 AM
88 Z-ROC's Avatar
I took the plenum an runners off and noticed "carbon build up" on the 2 right rear ports which leads me to believe the left rear injectors are "bad" to some point.
All gaskets are mounted correctly but i noticed that the plenum also got very hot.. Im thinking it has something to do with the egr..
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
86Base
Aug 8, 2015 01:34 PM
