Map Sensor Camaro 91 RS
Old Aug 16, 2012 | 07:50 AM
CamaroLover69's Avatar
Car: 1991 Camaro RS
Engine: 5.0L V8 TBI
Transmission: MX0
This is probably a very easy one. LOL
I cant afford to go to the mechanic again. I have a code 34. I will first check for crimped vac lines and just visually inspect the wiring to the piece.
If that all looks fine I think I will purchase the sensor and install it myself. I just wanted to confirm the process. I think I would disconnect the negative battery terminal, locate the piece (remove air filter if necessary) unscrew the one bolt holding the piece in (making sure not to drop the bolt) unplug the connecting vac hose and wiring and just reverse process back in.
Is it right that if I leave the battery terminal unplugged for approx 15 minutes that the codes will reset and then the computer will pick up and sorta plug and play adjust to the new piece or does it require adjustment?
Old Aug 16, 2012 | 08:22 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Map Sensor Camaro 91 RS
1 min will clear codes
http://www.chevythunder.com/map_code_34.htm
Old Aug 16, 2012 | 08:23 AM
Car: 1991 Camaro RS
Engine: 5.0L V8 TBI
Transmission: MX0
Thank you. All else seems correct?
Old Aug 16, 2012 | 08:37 AM
Car: 1991 Camaro RS
Engine: 5.0L V8 TBI
Transmission: MX0
Wow, didnt see that link the first time. THANK YOU!
9192camaro
16
Feb 3, 2019 12:21 AM
Caspar
Jun 19, 2016 11:19 PM
91REDZ28VERT
Aug 18, 2015 10:16 PM
squiggy2
Aug 9, 2015 09:30 PM
