99 suburban 350 vortec
Old Aug 16, 2012 | 06:48 PM
heath454's Avatar
hey guys im new here..i have a 99 4x4 suburban that has been giveing ne fits for along time.poor performance and gas milage runs ruff doggie .it has had everythang under the sun replaced ignition fuel system its been checked checked and rechecked no codes no issues just runs like crap..my first question is does anybody know if the flattop pistons could be screwing up the computer system on this truck.. i just wonder if the rise in c.r is messing up thangs pleas help thanks
Old Aug 16, 2012 | 07:02 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: 99 suburban 350 vortec
Did someone rebuild your engine?
Old Aug 16, 2012 | 07:09 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
I'd imagine, he mentions flat tops and a raise in compression...
FYI these are stock Vortec 350 pistons:
Old Aug 16, 2012 | 07:20 PM
heath454's Avatar
yes i was completly rebuilt
Old Aug 16, 2012 | 07:36 PM
1986_T/A's Avatar
Have you tried running 93 octane?
Old Aug 16, 2012 | 07:47 PM
heath454's Avatar
i have tried 89-91 cant get 93 in my area i have tried messing with the distributer..i dont get much results idk..no check engine lite it runs like crap idles really low like 475rpm and it surges at low rpm acceleration its just a piece of crap lol
Old Aug 16, 2012 | 08:02 PM
heath454's Avatar
we just took a trip i started out with a mix of 89-91 in the tank it ran sum better but got 13.4mpg we ran 175mi interstate onlits a 42gal tank i put 15 gal of 87 in it then tan 230 miles threw hills and hollers of ky it got 12.7 i put 17 gal of 87 in it ran 183 mile interstate back home and got 15..but it soes seem to performe just a little bit better with the higher octane just worse on mpg
Old Aug 16, 2012 | 08:17 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Turning the distributor won't do anything. The timing is controlled by the computer on them.
Old Aug 16, 2012 | 08:55 PM
1986_T/A's Avatar
My take? Your compression is too high for the fuel available and your computer is tuning down the hell out of the motor trying to compensate for that Compression and possibly engine knock.
Old Aug 16, 2012 | 09:16 PM
YEAHUNO's Avatar
Car: 91 Z28
Engine: 357 sbc
Had a similar problem on my 99 3/4 ton 4x4. CRC mass airflow cleaner! Truck runs like a champ now! Still only get bout 10 mpg. But Frank has 3" body lift n 37" Mickey Thompson Baja claws lol
Old Aug 16, 2012 | 09:27 PM
heath454's Avatar
i thank back about a 8 months ago we tried a maf sensor but i cant remember now been a long battle..i am really wondering about the c/r and the pistons i get two opinions some say its the prob and others say no way so idk..all i do know is a got a friend that has the excat same vehicle all stock original and his runs decent for a 7300lb vehicle and gets 17.5mpg on highway, i have seen it first hand..mine idles rough runs ruff gets 15at best and has to down shift to 3rd gear to hold 70mph on a small rolling hill..my dad has a 95 ext pickp 2wd we can put a large boat behind it equalling out the weight difference and it will run circles around mine and is smooth as silk
Old Aug 16, 2012 | 09:28 PM
heath454's Avatar
also when its hot it starts hard like advanced timming but no matter were i set the timming it still does it
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
86CamaroDan
Sep 29, 2015 10:08 PM
willyjoejr
Sep 3, 2015 09:26 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
