"Standard" ARP oil pump stud and M55A oil pump
Hey guys went to install my oil pump into my L05 block this evening and ran into a problem. With the stud installed finger tight and torqued to 55 ft-lbs with ARP fastener lube under the washer and nut, the stud does not protured above the top of the nut. You can see that the stud is about 4 or 5 threads short to stick out above the nut. I used ARP kit #230-7001 which is for the standard oil pump which is what my machine shop told me I would need for my M55a oil pump. My gut tells me I should run a longer stud (kit # 230-7003) to achieve this but is it all right to loosen the stud a few turns to achieve what I want. Or should I just get the longer stud?
Thanks.
PS: I measured the depth to ensure the stud wouldn't bottom out on the main bearing. I have about 1/16 to 1/8" clearance with the stud bottomed in the taper. FWIW.
Thanks.
Engine: 4++,350 & 305 CIs
Re: "Standard" ARP oil pump stud and M55A oil pump
Did you have the stud and pump body on when the crank bore was checked? or did you have the factory bolt on the pump?
I haven't used the pump stud before.
Maybe calling ARPs tech line will help you..
The original setup before the rebuild was the factory pump with a bolt. I phoned ARP they instructed to get the longer stud kit (230-7003). Install instructions are what I listed above: install stud finger tight, can back it just off the taper if desired, loctite not necessary. Put ARP fastener lube under the nut and torque to 55 ft-lbs.
If the block was machined with the factory bolt holding the pump, thats prolly what you should use.
If you had the stud on when it was machined then use that.
"supposedly" the stud and bolt pull different and could cause the bore to go outa round. You may be fine if its a street motor..
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Use the HV stud from ARP, the standard one is to short for the new body standard volume melling pumps.
Car: 1979 Malibu
Engine: Blown LSx
355tpipickup
Aug 25, 2015 12:54 AM
LT1Formula
Aug 20, 2015 09:36 PM
mcquigg
Aug 13, 2015 02:26 PM
