Possible overheat? Diseling on?
Old Aug 22, 2012 | 07:31 AM
xxZ28xx's Avatar
Car: 1988 Camaro, Holley 600 series.
Engine: 350 w/350 TPI heads
Transmission: 90+ 700R4
Axle/Gears: not sure
Started driving my car it runs pretty well.. I think I may still have to tune the carb a bit...
On to my question, I don't know if its overheating (none of my gauges work yet) but I could of sworn I smelled some coolant burning... Now my brother in law told me it could be some stuff I spilled in there because I did just start driving my car.... Last night when I was driving home in the rain I realized my hood was steaming when the rain hit it : ) Idk if thats normal for older cars with pure metal hoods or not..
My thermostat is at 180 degrees.. so I know it gets pretty hot in there.. I took out the heater core and bypassed it, I was wandering if having to much coolant could be a bad thing?
And the dieseling on I turn the key off and it does it maybe for a half second not even but its annoying and that half second feels like forever. A friend at work said that one of my cylinders may be overheating and still burning fuel when I stop...
So Im thinking its something with my timing because I just put a new distributor in and I thought I had it all timed right but I guess not, I also swapped it out for a carb which needs tuned..
Could a carb cause it to overheat if it is overheating? I mean I drive it from my house to work... about a 15 minute drive (not including the redlights) and it hasn't exploded yet lol..
Old Aug 22, 2012 | 09:19 AM
Gsoleski's Avatar
Car: 1984 Z28
Engine: Vortec 350, hotcam
Re: Possible overheat? Diseling on?
My car did this and the timing was far to advanced. Try bringing it down a little and see what happens. Also this is just me, but I wouldn't drive my car to much without properly working gauges. I'd at least get a cheap mechanical gauge from the parts store to watch the temp.
Old Aug 22, 2012 | 11:49 AM
xxZ28xx's Avatar
Yeah thats what my brother in law keeps saying.. I guess ill go get some cheapy ones till I can afford the good ones I want, makes sense..But I still need to drive it..
I think I fixed the problem? I put some more coolant in it and change the oil to a thicker wait.. It seems to be running awesome now.. I think I had 5 30 in before switched it to a 10 30 and put some stp oil treatment in and bought a K&N oil filter... runs fine now : ) Except for the dieseling on.. I can just turn my distributor cap to the left and right for a simple fix cant I? Which way to advance or decrease? Thanks for the help.
Old Aug 22, 2012 | 08:33 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
Clockwise to retard timing, may need to run higher octane fuel too if that doesnt work.
Old Aug 22, 2012 | 09:22 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
For the running on, throttle blades might be cracked open a bit too far at idle - what's the idle speed - over 800 in park?
For the overheating - is it actually boiling? Or u just paranoid
Old Aug 23, 2012 | 06:39 PM
xxZ28xx's Avatar
I was paranoid I bought a gauge today and it stays between 190-210 lol.. It may be the throttle blades.. but it also may be my ignition switch.. because I took it to advanced and the guy there watched me turn it off and said it sounds more like a delay in the switch..
And it was way out of time.. but I timed it and no more missing so that is good I need to un retard the timing a little bit because now it feels like I drag on forever... I think it needs to be at 6 degrees.. because my engine is from a vin F car.. and thats what it calls for. But my vin is E..
Old Aug 24, 2012 | 09:07 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
A 'delay in the switch' sounds bollocky to me, that's the sort of bs guys make up when they've got no idea. Run-on will usually be throttle, timing, possibly idle mix, or hot carbon deposits. Most likely one of the first two or three - ie should go away with correct tuning.
Forget that 6 degrees stuff and that vin stuff, that's the factory recommended base setting for tpi. You've lost the tpi and now have a Holley and mech/vac advance dist - different ball game now - give it the timing it wants to run best. Should probably be in the 12-16 degrees range for base timing.
Old Aug 25, 2012 | 09:38 AM
xxZ28xx's Avatar
Should it be before or after?
Old Aug 25, 2012 | 12:47 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Timing? Before tdc of course, won't run too good after
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
FormulasOnly
Jul 23, 2018 08:47 AM
steimel94
Sep 23, 2015 12:48 AM
bryan623
Sep 19, 2015 10:13 AM
