Low Idle
Old Aug 22, 2012 | 07:46 AM
1987LT's Avatar
Car: 1987 Camaro LT
Engine: 305 4bbl
Low Idle
I have a 1987 camaro carbed. Anything below 1500 rpm it starts to jerk. So i set the idle around 2000 rpm just to keep it running and it runs pretty good but when i try to shut it off it starts dieseling. Can someone tell me what i need to do?
Old Aug 22, 2012 | 03:09 PM
onthedownlow's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
Re: Low Idle
The fact that it's dieseling after you shut it off indicates to me that your timing is too far advanced. Retard the distributor and try it there. As for the jerking, not too sure. This post should be in Tech/General engine section.
Old Aug 22, 2012 | 03:45 PM
kauboy's Avatar
Car: 83 Z28 Crossfire
Re: Low Idle
It's dieseling because you got the idle too high. Might be a vacuum leak causing the rough idle / jerking.
Old Aug 22, 2012 | 06:14 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Low Idle
How long have you had the car? I take it that it had been running fine than this started happening out of the blue.Have you made any adjustments/worked in the bay/added parts recently ? If not than I would start with timing (how it adjusted its self to a unfavorable position is beyond me) First I guess I should ask if you know how to set your base timing with a gun first.If the answer is yes than if you have a timing gun it cost nothing to try.Back the rpms back to where it was before then take a look at where your base timing mark is that way you can put it back where it was if adjusting it dose not work. It may not be the answer but it can be a proses of elimination and you can cross that one of the list. Here's diagram showing 1987 to 1988 5.0 carburetor Camaros engine vacuum routing.
Old Aug 23, 2012 | 08:00 AM
1987LT's Avatar
Car: 1987 Camaro LT
Engine: 305 4bbl
Re: Low Idle
I havent had the car long at all. I took the engine coolant temp sensor out that was located on top of my thermostat housing cause my gauge wasnt working and i had to replace it with an aftermarket gauge. Thats when i started having problems.
Old Aug 23, 2012 | 08:34 AM
grygost's Avatar
Car: 1991 GTA Purple of all colors
Axle/Gears: Crappy 3.23
Re: Low Idle
Put it back in and see what happens.
Old Aug 23, 2012 | 08:36 AM
SumDumbGuy's Avatar
Car: 1987 Camaro
Engine: 355
Re: Low Idle
Did you ever read the replies to your post about that coolant temp sensor? The gauge doesn't work off the sensor in the tstat housing. You swapped the wrong sensor. The gauge is ran off the sensor in the driver side head. The sensor you pulled goes back to the ecm, not the gauge.
theshackle
Sep 17, 2020 08:26 AM
jklein337
Sep 19, 2018 06:23 PM
Prodigious
Oct 4, 2015 11:20 PM
perZ
Aug 21, 2015 05:51 PM
perZ
Aug 15, 2015 01:17 PM
