87 GTA stalling when hot
Old Aug 22, 2012 | 08:23 PM
Max Charron's Avatar
my 87 gta is stalling when hot, but restart pratically everytime. when cold its okay, i have bought the car last week. he have a aftermarket air intake ( but just the air flow on origin tubing), and he gave me code : EGR, MAP sensor low and high voltage, and ignition error. i've disconnect de IAC sensor, and it run a little bit more better but still stalling. help me please
Old Aug 23, 2012 | 07:52 AM
grygost's Avatar
Car: 1991 GTA Purple of all colors
Axle/Gears: Crappy 3.23
Re: 87 GTA stalling when hot
Heatsoak. Also throwing a bunch of codes like that I would check your alternator and make sure it is pumping out I believe 13-14 volts to the battery. Also stalling when hot could be a lean issue which in turn is linked to the IAC, MAF, and EGR.
Old Aug 23, 2012 | 08:43 AM
The gage in dash indicate 13 volt steady ,...
Old Aug 23, 2012 | 08:49 AM
grygost's Avatar
Cool, now check all your electrical connections for the sensors, something could be loose that is causing all the codes to pop up; also reconnect the IAC; not a good idea to have it disconnected considering it will tell the computer to richen or lean the fuel mixture based on air temp.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Strick1
Sep 4, 2015 07:11 AM
greenyone
Sep 2, 2015 03:39 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Winchester1094
Aug 18, 2015 10:23 AM
