Horsepower guesses? Dyno soon.
Old Aug 24, 2012 | 01:44 PM
FConn3's Avatar
Car: 1985 Iroc-Z Camaro.
Engine: Forged 383.
Transmission: TH350 with a Hughes 3500 stall.
Axle/Gears: Moser axles and a Richmond 4.10.
Hey I was wondering what you all thought about my setup and how much HP you think it'll put to the wheels on the Dyno. The cam is a hydraulic flat tappet if you were wondering, going to a solid roller this spring. Just check out on my signature what you think. I'm gonna be spraying 150 on it so you all could guess 1/4 mile times to if you want. Just to have a little fun with a discussion and start a conversation.
Old Aug 24, 2012 | 02:05 PM
UnstableAviator's Avatar
Car: 1984 Camaro
Axle/Gears: Ford 9"/4.30
Re: Horsepower guesses? Dyno soon.
That's a healthy looking recipe for a 355 you've got there, should run real strong. For track use, I think maybe a little more converter would be ideal, but it should not dissapoint as is. Angle plug 292 heads? I think those were only avaliable thru dealerships as an over the counter performance head. Nice find, they should flow pretty good.
Dyno guess? Through the unlocked converter - 325rwhp, assuming of course the timing and carb are tuned correctly.
Old Aug 24, 2012 | 07:40 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
With spray? Providing you can get traction and all the parts are well matched, there's no reason you can't get at least a mid 11 second pass. Might be closer to low 11's but getting into the 10's might be questionable.
Dyno HP is only bragging rights. That doesn't guarantee a low ET.
Old Aug 25, 2012 | 10:22 AM
jdracer13's Avatar
Car: 1982 Camaro
Engine: LTX Carb
Axle/Gears: 3.42 Posi
Are the heads Ported? Btw, your brave spraying on those old heads. I would say mid to low twelves with spray around mid 13's with motor depending on chassis work and car weight. probably around 400-425 on Engine dyno, and around 325-350 on chassis as stated above, (assuming the engine is tuned properly also depending on dyno setup and corrections). The only thing I would do is get a set of either ported Vortec heads cheap or Dart Pro 1 CNC ported heads. Thats just me. What does the car weigh?
Flow Chart for a worked 292 Angle Plug Head @25 pds, 4in bore (with the larger intake expect relatively the same if unported, inf ported expect a couple more percent)
.100 lift = 96.39cfm
.200 lift = 143.85 cfm
.300 lift = 190.14 cfm
.400 lift = 218.51 cfm
.500 lift = 243.59 cfm
.600 lift = 261.58 cfm
.700 lift = 271.18 cfm
Here is one for a stock Vortec Head no work
@UnstableAviator
These heads were only availible otc, never offered as production, I prefer the 461X heads worked over. We were going high nines low tens. the motor was a short stroke big bore 290ci with the 461X heads and STICK SHIFT. In an '82 Sport Coupe @ 2700lbs in SS/CS.
Old Aug 25, 2012 | 04:34 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
Im gonna guess high at 375hp at wheels no spray.
Old Aug 25, 2012 | 05:32 PM
FConn3's Avatar
Engine: Forged 383.
you all are about where I'm thinking.
Old Aug 26, 2012 | 03:15 AM
88monteSS's Avatar
Car: 92 RS/97 K3500/07 ISS
Engine: LT1/454/LS4
Transmission: 4L60E/4L80E/4T65E-HD
Axle/Gears: 2.73/4.10/3.29
I got bored and ran it through desktop dyno with as close of numbers as I could. I got the flow numbers through a google search, and the cam is different than the one you have, it was the only one that came up when I searched the included cam files for "Nitrous HP", I included a screen shot of the specs it used, if you can give me all the numbers it wants I can run it again and get a closer result. I might even get frisky tomorrow and plug it into desktop drag & see what it says...
File Type: pdf
Old Aug 26, 2012 | 06:28 AM
jrhaus76's Avatar
Car: 1989 IROC-Z28
Engine: L98 - 350 TPI
Transmission: MD8 - 700R4
Axle/Gears: GH3/G80 - 2.77 POSI
If that dyno is right, youre going to run past the redline before you even hit max HP.
Old Aug 26, 2012 | 09:09 AM
FConn3's Avatar
Engine: Forged 383.
Cam Style:Hydraulic flat tappet
Basic Operating RPM Range:2,800-6,800
Intake Duration at 050 inch Lift:250
Exhaust Duration at 050 inch Lift:263
Duration at 050 inch Lift:240 int./253 exh.
Advertised Intake Duration:284
Advertised Exhaust Duration:305
Advertised Duration:284 int./305 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.507 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.525 in.
Valve Lift with Factory Rocker Arm Ratio:0.507 int./0.525 exh.
Lobe Separation (degrees):113
Old Aug 26, 2012 | 12:50 PM
88monteSS's Avatar
Engine: LT1/454/LS4
That should be all the info it wants, I'll plug it in when I get home.
Old Aug 26, 2012 | 01:01 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
I think the heads are going to be the x factor here, not sure what they flow but that's where the horsepower is made.
Old Aug 26, 2012 | 01:46 PM
FtrSpeedy's Avatar
Axle/Gears: na/2.73
How do you figure that? Since he could turn that motor to 7k rpm.
Old Aug 26, 2012 | 06:14 PM
jrhaus76's Avatar
Car: 1989 IROC-Z28
Lol, I guess that's true. Brain fart by me, sorry.
Old Aug 26, 2012 | 09:52 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Without spray or porting sub 400 to the ground
You could make nice gains with that cam size to just go solid flat tappet.
Old Aug 26, 2012 | 11:56 PM
88monteSS's Avatar
Engine: LT1/454/LS4
I'm guessing the pn for your cam is 12-568-4, as that's what came up when I searched those numbers. Luckily for me the program already had that cam in its files, once I knew the pn I could find it.
Ran the sim twice, first is just motor, second is motor with a 150 shot. Let me know just how close it is when you actually get the motor on the dyno.
If you want I can run it through Desktop Drag, but since for whatever reason they decided not to put a single 3rd gen in the included cars, closest I can get aerodynamically would be a 4th gen
File Type: pdf
File Type: pdf
Old Sep 2, 2012 | 10:02 AM
FConn3's Avatar
Engine: Forged 383.
Buying a set of RHS aluminum heads.
Old Sep 5, 2012 | 10:01 PM
jdracer13's Avatar
Car: 1982 Camaro
Engine: LTX Carb
Linson
Oct 24, 2025 02:00 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
LT1Formula
Oct 8, 2015 08:34 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
skinny z
Oct 5, 2015 06:23 PM
