Computer-Controlled HEI Distributor Questions
Old Aug 30, 2012 | 01:40 AM
Jaime-TA-84's Avatar
Car: 1984 Firebird Trans Am
Axle/Gears: 3.73 Posi
I took apart my distributor to clean it up to use it on my new engine and found that it had red dried up grease around the upper bushing as shown in the attached picture. Everything I have read about HEI distributors has said that it is supposed to have a felt washer or plastic cover, but mine has neither. I also saw pictures of HEI distributors having small holes on the side of the bushing for the grease to go through to lubricate it. Mine doesn't have any.
What type of grease do I put in there? Wheel bearing grease? White lithium grease? Comp Cams Engine Assembly Lube?
Also, does the distributor shaft shown in the attached picture look worn? It is nice and shiny where the bushings surround the shaft.
Attached Thumbnails Computer-Controlled HEI Distributor Questions-imag0457.jpg   Computer-Controlled HEI Distributor Questions-imag0456.jpg
Old Aug 30, 2012 | 04:30 AM
IROCtheRoad's Avatar
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Re: Computer-Controlled HEI Distributor Questions
Wish I could help - free bump for ya
Old Sep 1, 2012 | 03:51 PM
Bump.
So no one has ever taken apart their distributor? I guess the majority of people just replace it with a new/rebuilt one then.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Jan 29, 2017 07:00 PM
stalkier
Aug 21, 2015 01:54 AM
midias
Aug 15, 2015 05:07 PM
stalkier
Aug 7, 2015 04:49 AM
