87 iroc camaro wont start help plz!!!
Old Aug 30, 2012 | 03:23 AM
sergio1310's Avatar
Car: 87 iroc 5.7 tpi
sup guys or girls,,, im in need of help plz.. i have a 87 iroc camaro that starts n shuts right back off,, i changed the fuel pump n does the same thing still..i have to spray starting fluid to keep it running n as soon as i stop it turns off,, today i checked the fuel relays n they r all burned out,, they still have power but they burned,, think its causing a bad connection??? wat other major sensors should i check n where r they located thannks for ur time n help,,, sergio
Old Sep 1, 2012 | 08:08 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
can you hear the relay turning on when you turn the key if so can you hear the pump
Posted from Thirdgen.org App for Android
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Wade787b
Sep 29, 2015 01:15 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 11, 2015 03:17 PM
