intake and head mismatch?
Old Aug 30, 2012 | 01:49 PM
Firebirda7x's Avatar
Car: 1986 Firebird Trans Am
Engine: Chevy 355
Transmission: Built 700R4
Axle/Gears: 9 bolt 2.77
Hello third gen. I am considering replacing my intake, carb, and heads if I cant make this combo i have work.
The previous owner of my 355 has a 600 CFM holley carb planted on a Edelbrock Bowtie II victor Jr intake (part # 2972) and has stock 441 heads. The cam is unknown (sounds nice though!) and I added Headman 1 5/8 headers.
I am almost certain that there is stepping going on inside those heads..i dont know if he ported them but even if he did why did he use this intake? And assuming they were ported, can they still work with this intake? is there some weird combo people used to use? He went through the trouble to put in a nice ignition system, chromed everything, and used a gear set instead of a chain (which sounds horrendous, imo).
With all the collective experience out there, has anyone else done this and had success or is there no rhyme or reason to his setup? My money is on the latter and I would rather throw on vortec heads and a new intake and carb...but if this combo will work i would rather save the $800 and keep this for a bit.
Old Aug 30, 2012 | 04:58 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
Re: intake and head mismatch?
Sounds like he matched the intake to the cam, will it work? What are your plans for it? Bigger question is whats the cam specs
Old Aug 30, 2012 | 07:04 PM
Engine: Chevy 355
Cam is unknown.
Old Aug 30, 2012 | 07:34 PM
Damon's Avatar
The standard 2975 Vic Jr. doesn't have very large ports in stock form- 1.90" x 1.10" according to Edflebrock. For comparison, the entry level Performer has 1.88" x 1.14" port openings- nearly identical and not that bad a mismatch for a near-stock set of heads.
I'm guessing he put on a single plne because it just looks cooler than a dual plane, not because it's going to make more power.
Gear drive..... I haven't found the application yet that required one. I also don't like the noise.
I get the feeling the previous owner was more into how things looked and sounded than the actual performance.
Old Aug 30, 2012 | 07:37 PM
FtrSpeedy's Avatar
Axle/Gears: na/2.73
I wouldnt worry bout heads an intake till you know the cam. There should be a stamped number on the front of the cam. Then look up the part number.
Old Aug 30, 2012 | 08:14 PM
Engine: Chevy 355
If I'm going through the effort to remove the cam should I just replace everything at once? There's a lot of potential there when everything is..u know...working together
Old Aug 31, 2012 | 08:49 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Considering the reasonable cost of a cam swap ( HF ) I feel it's worth it to have known specs. However, hard to do a good job picking a cam if you don't know the heads and compression. Running a mystery small-block is fine when you don't care about MPG or emissions, so long as you can get good driveability. If I liked it, I'd start by playing with gearing and maybe a torque converter. You're never going to make excellent power with those heads, and if the pistons are dished, then a healthy cam will hurt the lower RPM where those heads do work, sort of. Swapping an RPM AirGap with a 750 will dramatically outperform what you have, even with the rest of the combo. Either accept what you have, or start buying parts.
Old Sep 1, 2012 | 09:42 AM
Engine: Chevy 355
T
Well I went thru the effort to rebuild my 700r4 with one of Probuilt automatics 650 HP kits and a 9" edge racing converter (for future plans). Because of what you mentioned about my mystery small block is why I was uncertain about what to do next. If I got the 062 vortec heads, should I mat h a cam to those and my intake or get a dual plane manifold? I don't see many people using the one I have now, even when they would use an open Plenum design.
Old Sep 1, 2012 | 10:05 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Considering the converter, I'd pull the heads and look at the pistons, if I couldn't borrow a bore-scope. Your local machine shop might have one. If they're not flat-tops, put the engine back to running while you build something better to put under your Vortecs.
Old Sep 1, 2012 | 10:56 AM
FtrSpeedy's Avatar
Axle/Gears: na/2.73
If you plan on alot of street driving then ya switch cam head and intake. If you plan on near all track time then stick with your current intake.
Old Sep 1, 2012 | 08:49 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
With the others.
That heads couldnt keep up with that intake no matter what you did
Sell it ditch the geardrive and get a head/intake thats designed to work together
Old Sep 1, 2012 | 10:37 PM
Engine: Chevy 355
Actually I do have access to a borescope should I go in thru an intake valve on cylinder 1 and see if its a dome piston or flat top? If it's dome....I might as well redo the pistons huh
earlpote
Aug 28, 2015 10:42 AM
hayesaw0210
Aug 23, 2015 11:15 PM
theurge
Aug 21, 2015 12:46 PM
89mulletbird
Aug 12, 2015 07:08 PM
