car bogs under acceleration when cold
Old Aug 31, 2012 | 05:45 PM
xstang77's Avatar
hey i have a 91 bird with the l03 and when i drive it to work in the morning and go to accelerate it will occasionally bog down it was at its worst today to the point where i dont even think the car was running anymore then it just eventually came back to life it does this more noticably now that its getting colder, the mods on the car are k&n open element BBk underdrive pulleys,timing set to 4* advanced. any advice would be greatly appreciated thanks, jon
Old Aug 31, 2012 | 05:57 PM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
Re: car bogs under acceleration when cold
Does it get better/worse as the car warms up?
What have you checked so far?
Old Aug 31, 2012 | 06:32 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
A couple of things that come to mind are the coolant temp sensor. Do you have a way to read ECM data? If so, you would want to look at the ECT data PID and compare it to actual engine temp. If not, you can use an ohmmeter to test the sensor's resistance. It should test at 3500 ohms fully cold(70 degrees), and 180 ohms at operating temp (212 degrees).
Fuel pressure is hard to check on the TBI. I generally start by visually checking injector spray. The spray from each nozzle should be a nice solid cone shape with no open spots. When you snap the throttle, the spray should become fine and strong and touch the sides of the throttle bore. If it seems on the wimpy side or if there are sections missing from the cone, you need to check fuel pressure and either have your injectors serviced or replace them.
Old Aug 31, 2012 | 08:24 PM
xstang77's Avatar
the bogging gets better as the car warms up it usually only does it on the drive in in the morning, such as when i get on the onramp for the interstate sometimes if i get it right i can almost get it to somewhat backfire,the rest of the day its fine, i recently replaced the coolant temp. sensor, i wonder if all the cold air with an open element is contributing to it, i have bosch plugs in it now witch is causing a slight misfire but i just picked up some declo plugs from the gm dealership i work at gonna slap them in this weekend. i have a blaster coil so i think im gonna set the gap to .40 the car also smells like its running rich sometimes i really want to get it tuned but i cant find anywhere around here to do it. i have no way to view the data unfortunately however id like to get my hands on a tech1, ive also recently replaced the fuel filter. thanks for replying so soon guys
Old Oct 9, 2012 | 06:32 PM
xstang77's Avatar
still having this issue anymore ideas anyone?
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
86Base
Aug 8, 2015 01:34 PM
drathaar907
Aug 6, 2015 04:20 PM
