86 IROC 305 TPI to Carb 383 swap no start
Old Sep 1, 2012 | 05:26 PM
IroczFan's Avatar
Car: 86 IROC-Z
Engine: 383 Stroker Vortec
Transmission: 700r4 Built
Axle/Gears: 3:42
did a TPI to carb swap put in my 383 wouldt start then realized the TPI distibuter wouldt work so i took the one outta a 74 camaro and droped in there and all it did was back fire out the carb once never ran or anything it is a brand new motor and we have no clue what to do it has spark and gas just need some input on what could be wrong
Old Sep 1, 2012 | 05:35 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
timing. i would reset the dist and make sure your tdc if its backfireing it sounds like a timing issue
Posted from Thirdgen.org App for Android
Old Sep 3, 2012 | 06:47 PM
IroczFan's Avatar
Car: 86 IROC-Z
Axle/Gears: 3:42
Re: 86 IROC 305 TPI to Carb 383 swap no start
we have tried re setting it multiple times all it does is back fire im starting to think it isnt the right distributer
Old Sep 3, 2012 | 06:51 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
make sure the wires are in the tight order. also have a friend try to start it wile you adjust the dist a little bit either way.
Old Sep 10, 2012 | 02:25 PM
IroczFan's Avatar
Car: 86 IROC-Z
Axle/Gears: 3:42
tried adjusting it and it doesnt change anything
Old Sep 10, 2012 | 03:11 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
are the rocker arms set correctly if intake is staying open it could cause a backfire in the carb.
Old Sep 11, 2012 | 12:21 AM
IroczFan's Avatar
Car: 86 IROC-Z
Axle/Gears: 3:42
some where loose so we tightened them up alittle also gapped the plugs and it seems to make a hige differance but still didt run it wants to so bad but wont, so we pulled the plugs to check them and the back 2 on each side seem to be getting gas one or two where alittle black and the front ones didt seem like they had much gas at all and i know for sure the car is getting gas no problem... the car is up on ramps in the front but i dont see why that would matter for only the back plugs to get gas
jaridjohn
Jul 8, 2024 03:49 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
1nastygta
Oct 28, 2015 08:51 PM
Brcharrelson
Aug 26, 2015 07:47 PM
drathaar907
Aug 6, 2015 04:20 PM
