BBC intake ??
Old Sep 4, 2012 | 08:53 PM
mackjar66's Avatar
Car: 1989 GTA
Engine: pending install 383 tpi
BBC intake ??
OK I have two BBC GM intake manifolds one bears the # 3931067 which represents a 396 intake. The other intake looks the same in design however it is taller with longer runner lengths. The # 3931087. I cannot find any solid information on this second intake. Can anyone help me out?
Old Sep 4, 2012 | 09:05 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: BBC intake ??
Comes up as another late 60's early 70's 396 intake.
Old Sep 4, 2012 | 09:06 PM
mackjar66's Avatar
Car: 1989 GTA
Re: BBC intake ??
where you finding that? im looking for the engine HP rating and vehicle that this intake was on
Old Sep 4, 2012 | 09:43 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: BBC intake ??
Original HP rating is no help. Manifold height is according to original vehicle. In theory the taller intakes should help power, but with those old factory castings, there's not much difference without extensive porting. If both manifolds are free, test-fit both under whatever hood you have. Shorter manifolds allow more air filter height, but stock castings are restrictive enough that this won't be much of an issue. Think of these as place-holders until you can buy something more modern. Even Edelbrock's Performer EGR or Weiand's new "peanut-port" Street Warrior will far out-perform either of the 2 you have.
Old Sep 4, 2012 | 09:50 PM
mackjar66's Avatar
Car: 1989 GTA
Re: BBC intake ??
ok maybe I havent been clear. I do not plan on using either intake since the edelbrock comes with this 427 I am purchasing. I just want the info on the second intake since all my searches have come up empty.
Old Sep 5, 2012 | 04:40 AM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: BBC intake ??
http://www.camaros.org/forum/index.php?topic=278.0;wap2
And through a bunch of other links, 396 P/U back in 68. Doesn't make sense due to the longer runners... but hey, maybe the internet is wrong.
Old Sep 5, 2012 | 03:44 PM
mackjar66's Avatar
Car: 1989 GTA
Re: BBC intake ??
maybe longer runners is the wrong term to use. The intake itself is taller then the regular car 396 intake. Thanks for the info
Loudnproud86
Jul 14, 2016 12:59 AM
customblackbird
Oct 1, 2015 04:30 PM
toronto formula
Sep 10, 2015 07:31 AM
dimented24x7
Sep 6, 2015 03:51 PM
SG91camaro
Sep 5, 2015 10:27 PM
