open element help
Old Sep 10, 2012 | 04:20 AM
tsha6189's Avatar
Car: 92 camaro rs
Engine: 305 tbi
Transmission: t-5
Axle/Gears: 4th gen posi 3.43
open element help
Hello, I just got a 92 rs 305/5sp and the previous owner put an open element air cleaner on it and now there is a hose that used to go to it just dangling, wondering what i need to do with it plug it etc. Thanks for the help.
Old Sep 10, 2012 | 05:18 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: open element help
It's a vacuum line.. But, you need to show pictures or something.. Is it an aftermarket air cleaner or OEM ? Does the line come from the Aircleaner or someplace else on the car?
Old Sep 10, 2012 | 05:42 AM
tsha6189's Avatar
Car: 92 camaro rs
Engine: 305 tbi
Transmission: t-5
Hey, thanks for the reply. Its an edelbrock open air element and the hose is about 1 inch or so in diameter and appears to go to the top of the tappet cover. Can't get pics right now but it comes up off of the tappet cover on the rear passenger side of the motor and i believe it hooked up to the original air cleaner but the edelbrock doesn't have a place for it. Just wondering if i need to plug it or put one of those little filters i see sometimes in the hole or just leave it as is. Thanks again.
Old Sep 10, 2012 | 06:25 AM
It's the fresh-air supply that provides makeup air into the crankcase to replace what is vacuumed out by the PCV valve.
Needs to be clean and filtered.
Punch an appropriate hole in the base of the inferior open-air thing, and put in one of those little breather filters like the beter stock setup would have had.
Old Sep 10, 2012 | 07:30 AM
tsha6189's Avatar
Car: 92 camaro rs
Engine: 305 tbi
Transmission: t-5
Ok great thanks for the reply i will get a filter for it and get it taken care of. appreciate it fellas
Falcon50
Aug 22, 2020 03:26 PM
Pac J
May 17, 2020 10:44 AM
FueledSoul
Sep 29, 2015 08:58 PM
drumstixer
Sep 29, 2015 03:02 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
