88 iroc 5.7 what fly wheel for starter?
Old Sep 12, 2012 | 06:56 PM
robeil3062's Avatar
Car: 1988 iroc-z
Engine: 350 tpi ,5.7
Axle/Gears: got me
Hi, I have an 88 iroc 5.7 auto. im prty sure my starter is going bad on it making a rly load noise when I turn the key. So im going to be buying a new starter but I dont know what flywheel or if its a flexplate i have? I have Im prty sure its the 153 but I can't find my answer on here if it the 153 will these starts work on my car?I called autozone and a rebuilt starter is 178$ and if these two will work what one is better? thanks for the help.
http://www.summitracing.com/parts/SUM-829000/
http://www.summitracing.com/parts/PWM-9100/
Old Sep 12, 2012 | 07:22 PM
robeil3062's Avatar
Car: 1988 iroc-z
Axle/Gears: got me
Re: 88 iroc 5.7 what fly wheel for starter?
ok il been reading and i seen some ppl say not to get the mini starts bc the are made for racing and dont last long should I just get the same one i have on it now?
Old Sep 12, 2012 | 07:36 PM
jas2730's Avatar
Car: 89 IROC Z/88 IROC Vert
Engine: 350c.i./305c.i.
Transmission: 700R4/T-56
Axle/Gears: 3.42/4.10
they make starters that work with the 153 and 168 tooth flywheels, so just grab one of those.
Old Sep 12, 2012 | 07:50 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
If you have an automatic trans you have a flexplate and not a flywheel. You should pull the starter out and check the flexplate teeth to make sure they're not chewed up or damaged . If they are a new starter won't help at all
Old Sep 12, 2012 | 09:02 PM
robeil3062's Avatar
Car: 1988 iroc-z
Axle/Gears: got me
ok ill check that out thx for the advice
Old Sep 12, 2012 | 09:45 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
You can use a mini starter if you want to. Its better than factory and lighter.
Old Sep 13, 2012 | 11:13 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
153 tooth flexplate is OE on your car.
Use a mini starter. Better all around. They became OEM on GM vehicles starting in the early 90's
Old Sep 13, 2012 | 11:25 PM
robeil3062's Avatar
Car: 1988 iroc-z
Axle/Gears: got me
so i bought a psl-100 mini starter its being shiped to me when I took the old starter off I saw that it was cracked is that just from age? Or is there something wrong? and I looked at my flexplate and thereS like 1 or 2 teeth missing do I rly have to get that replaced? or will it run untill I can come up with the money Im in texas right now and im going to be driving the car to cali will it be ok ? o.o Thanks!
Old Sep 15, 2012 | 08:56 PM
robeil3062's Avatar
Car: 1988 iroc-z
Axle/Gears: got me
bump
Old Sep 15, 2012 | 11:07 PM
jas2730's Avatar
Yep. You need to replace it.
Old Sep 15, 2012 | 11:44 PM
robeil3062's Avatar
Car: 1988 iroc-z
Axle/Gears: got me
its only 1 tooth =/ what would happpen if i didnt replace it ?
Old Sep 16, 2012 | 12:19 AM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
You would chew up starters quickly and probably damage the flex plate more which would continue to accelerate the destruction process. You might get away with it starting a few times but you're only asking for trouble. It's a really bad choice to make
Old Sep 16, 2012 | 03:42 PM
robeil3062's Avatar
Car: 1988 iroc-z
Axle/Gears: got me
dang well thats not good news =/
thanks for the replys
Frozer!!!
Jan 19, 2024 04:55 PM
jharrison5
Aug 19, 2015 05:53 PM
mustangman65_79
Aug 11, 2015 03:17 PM
milk
Aug 10, 2015 06:26 PM
Fronzizzle
Aug 9, 2015 01:15 PM
