Where to buy HVAC vacuum supply line?
Car: '84 Camaro Sport Coupe
Engine: 355
Axle/Gears: 3.08
I didn't know what other section to post this in but,
My air would only blow out from the defroster vents so I tracked the vacuum lines to find the problem. I found that the main vacuum supply line isn't letting any vacuum flow. (Is "hvac vacuum supply line" the correct name for it anyway?) I want to replace it but I can't find one anywhere online.
Does anyone know where I could get one online?
Thanks.
Thanks.
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: Where to buy HVAC vacuum supply line?
Don't know about buying it online, but as long as you know the size you need, you should be able to get it at any parts house locally.
AutoZone, Advanced, O'Reilly's; as well as NAPA, "real" parts stores, and so forth. Maybe even Meijer or Wal-Mart.
Basically, ANYWHERE that has a more complete line of auto parts than, say, Kroger.
1992 Trans Am
May 10, 2023 07:19 PM
mdtoren
Aug 16, 2015 05:45 PM
