no start
Old Sep 17, 2012 | 07:58 AM
lakeport's Avatar
Car: 1988 GTA Trans AM
Transmission: 5 speed
no start
so the battle continues, have been havin g issues with my car starting, long crank times, finally got the timing set and the starting problem seemed to be resolved
I drove to work this am, went fine, tried to start once at work, now it wont crank, makes one click and thats it
question, if the connection on the starter came lose while driving to work, would it stay running? I know if its lose it wont start, but if it came lose while running would it stay running and then not start on next try
stuck at work, really need to get the car started
88 trans am GTA 305, 5 speed, TPI
Old Sep 17, 2012 | 05:26 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
once the motor is running it usually will contunue to. if it came lose it could still run fine but not be able to start the car check the batt connections first and then i would double check the starter
Posted from Thirdgen.org App for Android
Old Sep 17, 2012 | 07:33 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: no start
Check all grounds and battery connections.
Old Sep 18, 2012 | 11:24 AM
lakeport's Avatar
Re: no start
So the cap on the top of the starter was lose, one bolt lose, the other missing, gotta find a new bolt, then test and hopefully re-install and all good.....wonder how this happened
Old Sep 18, 2012 | 11:44 AM
wrc's Avatar
wrc
Re: no start
great info, i am have the same prob with my 91 rs. i thought it could be the dam VATS or starter solenoid. it will start like 15 times no prob the nothing 1 click a few time then back to norm. and it is getting worse in the last few days.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
