HELP PLEASE! 1990 GTA
Old Sep 18, 2012 | 07:14 PM
GTAZero's Avatar
MY GTA shakes horribly and wont go past 25-40 mph not matter how much i push the gas. Ive had the distributor and spark plugs changed. Anyone have had a similar issue or know what my next move should be?
Old Sep 18, 2012 | 10:03 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: HELP PLEASE! 1990 GTA
Check for codes?
Old Sep 19, 2012 | 03:32 PM
Derek The Great's Avatar
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
Check to make sure your firing order is correct and that your wires are pressed on your plugs and distributer all the way.
Old Sep 19, 2012 | 04:23 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
when you changed the distributer did you line it up correct when installing it. Also check to make your plug wires are correct.
Old Sep 20, 2012 | 05:58 AM
Ryan3834me's Avatar
Car: 88 TA
Engine: 383
Axle/Gears: 2.77
https://www.thirdgen.org/forums/tech...m-getting.html
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
1990FirebirdGTA
Sep 22, 2015 07:26 PM
ssgt usaf
Sep 21, 2015 12:45 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
