edelbrock tpi intake weirdness?
Old Sep 18, 2012 | 06:27 AM
lsd88ta's Avatar
Car: 1988 Firebird Trans Am
Axle/Gears: 3.27:1 LSD 9 Bolt Disc Rear
I just bought the edelbrock hi flo tpi intake from jegs september 2012.. and.. the intake ports are different on each side.. I don't know if this is a fault or if this is normal? the injector boss' seem to be drilled higher in the port on one side of the intake..
Old Sep 18, 2012 | 06:39 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: edelbrock tpi intake weirdness?
I haven't seen the Edelbrock intake before, but looking at that I'd say it's hosed up. It looks like the one side slipped when drilled and now is in the gasket surface. I'd call up JEGs and let them know. They should let you swap it out. I'm pretty sure they even pay for return shipping. If they try backing out of the deal provide the picture URLs and have the tech look at it. There is no way I would use that as that's cutting into the gasket mounting surface and you could have issues like air and fuel getting into the oil gallery or leaking outside. Fuel and hot parts do not mix well.
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
I don't have a definite answer, but I would be concerned. The 2 respective top pics look to be correct, the bottom ones have the injector hole drilled through part of the intake gasket surface. Looks like a quality control slip up.
Old Sep 18, 2012 | 06:46 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Return this one.
Old Sep 18, 2012 | 07:21 AM
lsd88ta's Avatar
ok thanks for the help guys. looks like I'll return it.
Old Sep 18, 2012 | 09:31 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
too bad thats messed up, must cost you a small fortune to send it back
Old Sep 18, 2012 | 10:08 AM
Edwardgp's Avatar
Engine: 454-350
No quality control?
Old Sep 18, 2012 | 10:34 AM
Engine: Lb9
Transmission: M20
Originally Posted by Edwardgp
No quality control?
Doesn't seem like it
https://www.thirdgen.org/forums/tpi/...-manifold.html
Old Sep 18, 2012 | 10:36 AM
lsd88ta's Avatar
I did notice this picture of a guy porting the stock tpi intake.. it has the notch above the port but the ports on stock seem to have extra meat around the hole where edelbrock doesn't.. so.. the edelbrock with a bit of porting might be able to be saved I dunno?.. I don't know what the edelbrock tpi ports are supposed to look like.. but I know mine are miss matched a fair bit.
http://www.facebook.com/#!/photo.php...type=3&theater
Old Sep 18, 2012 | 10:46 AM
lsd88ta's Avatar
Originally Posted by tunedperformanc
yeah makes me want to either leave it stock while it's working, or switch the whole topend with afr heads and a miniram. will have to save a bit for that one lol.
Engine: Lb9
Transmission: M20
do you have a felpro 1204 to place on the manifold too see how it will seal ?
Old Sep 18, 2012 | 11:01 AM
lsd88ta's Avatar
I'm not sure, but I have supposedly the correct kit
http://www.jegs.com/i/Fel+Pro/375/MS93035-1/10002/-1
I did check and with the gasket lined up properly it covers maybe 15% of the injector hole on that bad side.
intake gasket says fel-pro 90314-1
Old Sep 18, 2012 | 11:14 AM
lsd88ta's Avatar
sitting the gaskets on as perfectly as possible... ehhh it don't look good lol
from what I can see, you'd have to cut into the gasket to just clear the injector hole..so sealing would have to be a problem. so I dunno, I think that's it. back in the box to get a refund hopefully.
Old Sep 18, 2012 | 11:35 AM
Engine: Lb9
Transmission: M20
Looks miss drilled, you might try contacting edelbrock directly
Old Sep 18, 2012 | 11:41 AM
lsd88ta's Avatar
I might do that actually, see what they say.
Old Sep 18, 2012 | 12:24 PM
Edwardgp's Avatar
Engine: 454-350
That one is not going to work.
Old Sep 18, 2012 | 01:10 PM
lsd88ta's Avatar
yeah I would agree. thanks for your help.
Old Sep 19, 2012 | 12:51 AM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Is another thread about a guy sending back three of these intakes recently due to the same problems and he was plagued with sealing problems.
You may get another one that is in the same condition. There is a known bad batch of intakes that edelbrock has chosen not to recall. That is some American made quality for you. Good luck!
Old Sep 20, 2012 | 03:02 AM
lsd88ta's Avatar
thanks for the info. yeah that is what I fear about getting an exchange manifold, and at this distance with the postage costs, I can't really risk trying more edelbrocks, so I think I will choose to go a different route, either porting out the stock manifold and using as&m runners.. or just going to a miniram or something.
Old Sep 20, 2012 | 09:17 AM
PhoenixFirebird's Avatar
Car: 1989 Firebird Formula
Engine: 385
Transmission: Full Manual TH350
Axle/Gears: Moser 9" 3.70
Maybe look into a FIRST intake base. I've heard they are the best out of the aftermarket TPI intake bases.
Old Sep 20, 2012 | 09:39 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Might have been a better bet to have gotten that somewhere locally, more recourse for a return. Unless importing was cheaper, but that's the risk you run I guess.
1992rs/ss
Jan 31, 2025 05:10 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
