1987 IROC-Z 350 TPI Engine Block Casting Code
Old Sep 19, 2012 | 09:28 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Whats up guys? I need a quick favor. Who has a OEM stock 350 TPI block? Im looking for the casting code so that I can buy a new block. Im seriously planning on building a 383. Any help would be appreciated.
I know that there are a lot of engines but there is one inparticular that I have but it has many different features for the very same part number...
Here is the site that I know of.... http://www.chevy-camaro.com/chevy-ca...es.asp?group=6
My current block is the 350 4 bolt main... 14093638 1987-95 350
2/4 Roller or flat tappet cam one-piece rear seal
Old Sep 20, 2012 | 01:32 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 1987 IROC-Z 350 TPI Engine Block Casting Code
My current block is the 350 4 bolt main... 14093638 l
New from dealer "new" or used block for rebuilding ?
Vortec # 10243880..is probably the most common junkyard equivalent roller cam block you will find these days ( other than your '638 block )
comes in 2 or 4 bolt mains
Look in '96+ trucks and vans
Old Sep 20, 2012 | 09:31 AM
vetteoz!! Good morning. Yeah I'm looking for a used block to revive. So is this block similar as my 683, as in the tapped bolt holes and such? You mentioned vortec as well. I do know vortec heads are very much different than standard heads do to the angle of the bolts, but will my standard intake and AFR 195 heads (1040) bolt up flawlessly?
Old Sep 20, 2012 | 09:40 AM
Or better yet, what the difference here between the 3?
http://www.gmpartsdirect.com/perform...CATID=628.html
theshackle
Mar 5, 2017 06:37 PM
The_Phoenix
Sep 3, 2015 10:56 PM
camaro71633
Sep 1, 2015 10:24 AM
gta power
Aug 13, 2015 06:15 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
